Do i need to change my propellers
1079 12 2018-6-22
TicTacc
Flight distance : 64636 ft
Hi, today i used my spark indoor ( without prop guards ) and touched my ceilling , i would like to know if i need to replace propellers.
It's seems to be paint.
Ty.
2018-6-22
Ram-UK
Flight distance : 1173045 ft
Remove the props and check carefully for any damages /broken pieces inside the motor.
If it's just the paint I wouldn't bother changing the props.
2018-6-22
djiuser_uMitnAZejgn9
Flight distance : 10876 ft
I agree with you Ram-UK
2018-6-22
TicTacc
I just checked and it doesn't seem to have any damages or broken pieces inside the motor, thanks you for your help.
2018-6-22
TicTacc
And i tested it with the same propellers and it seems ok.
2018-6-22
Hi, I think it is fine since it is just a small scratch but if you have extra propellers it is better to change it to be sure. Is there another part of the drone that is damaged?
2018-6-22
TicTacc
Hi, no the drone is ok he didn't crash, i grab it when he touched the ceilling.
2018-6-22
DMX_MT
Malta
DJI Paladin Posted at 2018-6-22 08:28
Try to avoid flying indoors Buddy !
2018-6-22
jacksonnai
be careful while flying indoor
2018-6-23
TicTacc
That was my first and last flight indoor ;)
2018-6-23
TicTacc Posted at 2018-6-22 08:31
Good to hear that the drone did not crash. As mentioned above, do not use the drone indoors to prevent this kind of incident. Avoid flying in areas where the GPS signal is weak and flying in confined spaces,
2018-6-26
Noble797
Flight distance : 42605 ft
Indoor flight is a killer, was flying in a gym and accidentally hit the home button. $150 repair bill later, I learned my lesson. Although, my accident might of been prevented if I had prop guards on. As for blades, I would check for motor damage and then just replace the blades. Blades are inexpensive and you don’t want them to fail mid flight.
2018-7-25
Flighty
Flight distance : 1977175 ft
Croatia
Paint scratch on the, end of the blade,, no problem.. Damage at the root of the blade then requires blade replacement!,
2018-7-31
