DJI Inspire 2 Firmware Update V01.02.0200
3761 44 2018-7-27
The Introvert Speaks
Flight distance : 3491430 ft
2018-7-27
Denis SF
Flight distance : 1783087 ft
I have the latest update for I2 and I have the same problem.
Message landing gear during the flight.
IMU which switch.
Drift of the dial.
DJI? Explinations ? Should we downgrade?
2018-8-7
Denis SF Posted at 2018-8-7 08:18
I have since downgraded to the previous firmware. I am not comfortable using the latest firmware at this time.
2018-8-7
Denis SF
The Introvert Speaks Posted at 2018-8-7 08:22
I will do the same. Good day and thank you.
2018-8-8
Denis SF Posted at 2018-8-8 23:33
Happy to help. I'm sure DJI will have a fix for this very soon.
2018-8-9
IntrepidDrone
Flight distance : 3620226 ft
I had a commercial shoot yesterday and had to downgrade firmware to previous. The new firmware is a disaster, terrible gimbal drift, unstable and big horizon tilt.
2018-8-11
goldrock
Flight distance : 2303451 ft
IntrepidDrone Posted at 2018-8-11 18:04
yep, same here. Downgraded as well.
2018-8-11
Denis SF
Bonjour Même problème et nous avons 2 machines! Peut-on utiliser un drone instable à 25 000 €? Nous voulons vous donner le temps de résoudre les problèmes liés à Inspire 2, mais cela fait plus d’un mois que nous attendons! Silence de la radio? DJI? ...
2018-8-28
Denis SF Posted at 2018-8-28 08:06
Hello
Same problem and we have 2 machines!
I agree I have since resorted back to the previous firmware which is not ideal either.. It likes to wander!
2018-8-28
Denis SF
The Introvert Speaks Posted at 2018-8-28 08:07
Do you have the camera drifting?
2018-8-28
With the latest release, yes! Not so much when I reverted back to prior firmware.
2018-8-28
Rob W
Flight distance : 96152 ft
I've had camera drifting with .200, too. Horizontal drifting back and forth. Every calibration possible was done after the firmgrade, as I always do.
2018-8-28
Rodger8
Flight distance : 20145135 ft
Try it with GO 4 ver 4.03
2018-8-29
Denis SF
Rodger8 Posted at 2018-8-29 06:54
I will try today and come back to you.
2018-8-30
Flo the Pirate
Austria
Denis SF Posted at 2018-8-30 00:04
How did it work out for you?
when i use the latest dji go app on ios i don´t see an update to .200 firmware available ... did dji pull it from the server ? when i connect a cendence with the latest firmware on crystalsky/android as a slave controller I can see an .200 update fore the inspire 2 !?!? Kind of wired isn´t it ?
2018-8-30
DRAGenDROP
Flight distance : 26170253 ft
goldrock Posted at 2018-8-11 23:21
how to downgrade and to what version?
2018-8-30
Denis SF
Flo the Pirate Posted at 2018-8-30 09:47
I did a test flight yesterday with the Inspire 2 and with the last update 0200.
I only had the landing gear error message once. I did not have the IMU change problem anymore.
For the drift of the camera, the X7 is well behaved.
I had also updated the App on 4.3.
For my other Inspire 2, I am offered the update 0200, I think I do but I hesitate.
2018-8-31
Flo the Pirate
Austria
Denis SF Posted at 2018-8-31 00:35
Hi Denis,
thanx for the reply ! glad it works for you now !
2018-8-31
fans90e289eb
Hello was wondering what the best firmware version is for my Inspire 2
2018-9-2
fans303c5328
Flight distance : 6143999 ft
Argentina
Hi guys anyone know a way of going back to original first Firmware?
2018-9-20
Matthew Dobrski
Flight distance : 1831050 ft
fans303c5328 Posted at 2018-9-20 13:44
For reasons beyond my understanding you can't just install any FW version ever released for Inspire 2. Another words, some installations are irreversible. You can, however, try to downgrade from particular version a step or two. DJI Assistant software will let you know how far back you can go. In the case of problematic .0200 you may be able to restore FW back to .0100 version, perhaps even further down, I don't remember. Also, I don't know which version introduced wobbly hovering issue to some aircrafts out there, since I've got mine after this disaster and loaded with .0100. So far no major issue in terms of flight stability or overall performance.
Said that, I've heard about some hacking applications available on web, which may allow to do just what you want. This is, however, desperately risky approach IMHO.
2018-9-20
fans303c5328
Argentina
Matthew Dobrski Posted at 2018-9-20 14:35
Thanks Matthew ! do you refer to V01.02.0100 the one from 2018.04.18?
2018-9-20
Matthew Dobrski
fans303c5328 Posted at 2018-9-20 16:31
Assistant software will display a list of all FW versions compatible with Inspire 2 recently. Once you connect your bird with computer it'll show what version she is on and what options are available. Keep in mind, however, that downgrading to .0100 may solve issues introduced with .0200, but not necessarily unstable hovering issue. Mine is hovering nicely with .0100, which doesn't mean your's will behave the same. Do you remember when did you noticed this nasty dance for the first time? You're not alone with this issue, but apparently not all Inspires have been harmed some time ago after particular FW update.
2018-9-20
fans303c5328
Argentina
Matthew Dobrski Posted at 2018-9-20 17:47
Hi, do not remember if it always did it or if starts since the last firmware ......But is not good ! They should fix it !
2018-9-24
Denis SF
Hello DJI,
Are you still on the issues of updates? We still have no news?
2018-9-24
fans303c5328
Argentina
Denis SF Posted at 2018-9-24 06:41
Hello DJI,
Yep and no news.
2018-9-29
vpierre
Suriname
more than 2 month we are waiting now,and no news thank for care about your customer
2018-10-1
Hello DJI,
No news yet... SAD!
2018-10-1
Yep i agree....
2018-10-1
vpierre Posted at 2018-10-1 06:01
Yeah, I don't know what's going on...
2018-10-1
gersphoto.orange
2 months, no 1 year
2018-10-1
FanOfFlight
Flight distance : 1983760 ft
Would be really nice to get some feedback and when the corrections in .200 are likely to be available.
2018-10-1
flyingfun
Flight distance : 2551998 ft
FanOfFlight Posted at 2018-10-1 18:34
would.nt be this week it holiday week in china .
2018-10-1
Rob W
flyingfun Posted at 2018-10-1 20:09
I doubt we ever will get any updates/information until a new firmware is released. Even when DJI staff works, we don't get any real and informative information. DJI don't know how to communicate with their customers.
2018-10-1
Paul Joy
Flight distance : 3754318 ft
This does seem extremely unprofessional. We purchased our Inspire 2 and X7 in May and our main reason fro choosing this platform was to be able to shoot in ProRes RAW. We thought we only had a couple of weeks to wait for ProRes RAW to be released but here we are nearly five months later and still no word from DJI other than some badly translated messages about engineers working on it being released over and over again!  This is a £12.000 professional film rig yet DJI don't even think it's customers deserve a decent update.
2018-10-2
Rob W
Paul Joy Posted at 2018-10-2 00:44
Sad but true. Their professional line gets the least support. It's all about marketing and selling hardware. When any new DJI hardware comes out, it is either buggy or missing announced features. When the hardware is at End Of Life - perhaps the features or bugs are fixed, but often not. Then a new version of the hardware comes out and the wheel turns again.
2018-10-2
FanOfFlight
Rob W Posted at 2018-10-2 08:55
Well, the way the hobby flyer world of drones is being attacked in pretty much every country (eroding that market), DJI will learn the guys flying commercial gear are the only ones left - the faster they understand this the better for them and those flying the more commercial products.  But with that said, they need to improve their testing of firmware before it goes out the door.
I have seem posts here from people that were in the beta test groups, that are saying some of the issues coming up were never seen in the test groups software....  this makes me wonder about what they do to the firmware after the test group is done with it and before its rolled out.
2018-10-2
Rob W
FanOfFlight Posted at 2018-10-2 11:23
Yes, I was in the beta, too. But now they have shut down a lot of it. So it sure won't get better.
If DJI had the ability to communicate with their customers, to be willing to take constructive criticism and start working with their customers, things would be better. Now they release half-finished products as fast as they can, with bad support on it after release.
2018-10-2
FVP
I fly with 0330 firmware since april 2017 because it's the most rock solid firmware ever made by DJI...
2018-10-3
PH3KS
Flight distance : 39537 ft
Really difficult to understand that “DJI, The world’s leader in civilian drones and aerial imaging technology” Can’t produce reliable firmware.
Its just not there main priority!!
2018-10-3
