NO signal issue. No live feed on my phone from my AC.
1120 11 2018-8-12
djiuser_hxwIeGObl05i
Philippines
Hi Everyone,
I updated the latest firmware both RC (V 01.00.0600) and AC (V 01.00.100) and DJI go 4 (V 4.2.21) which was instructed recently on the update.
I flew my drone on the day i updated the firmwares. I also flew my drone yesterday three times. After my last flight yesterday, i tried to connect again to fly it again but an error on the on the overall status showed up. Error is "Abnormal Status" The errors there was "Camera Sensor Error" and  also "Aircraft Encoder Error".
I tried restarting the drone, on off, then remove battery, as well as RC and the Phone. All of a sudden the live feed went back. But it after few seconds it went back to the Error.
The error on the drone is NO signal, but the home point is updating, the aircraft can fly manually using RC controlls, then, camera gimbal control is working, but i aint having the live feed on my phone.
I already tried downgrading the firmware of RC and Drone but error still persist.
To sum it up:
1) NO signal error - along with camera sensor error, and aircraft encoder error
2) If i use phone and AC connection only, it can detect the SD card, but if phone, RC and AC, it cannot detect the SD card.
Please help. This is very frustrating.
I attached the error. Please help.
2018-8-12
Hi there, just to verify, has the drone been involved in the crash or hard landing before? If not, we sincerely suggest to send the unit in for diagnosis, you may write an email to support@dji.com to start a case. Sorry about this.
2018-8-13
SparkYeL
Philippines
DJI Susan Posted at 2018-8-13 05:19
Hi there, just to verify, has the drone been involved in the crash or hard landing before? If not, we sincerely suggest to send the unit in for diagnosis, you may write an email to  to start a case. Sorry about this.
Hi Susan, I haven't crashed it or error in landing. Dont you have othr inputs what might be the problem.. i really wanted to know.
2018-8-13
SparkYeL Posted at 2018-8-13 06:43
It looks like the hardware issue as the firmware refresh doesn't work. I'm afraid that this cannot be figured out remotely, so I suggest to send it in for diagnosis. Sorry about this.
2018-8-15
Joller79 DK
Flight distance : 26447 ft
Try a nother micro sd card...  I got the encoder error on one i fixed, because no sd card was in it
2018-8-15
Jakab Gipsz
Hungary
This is hardware error. Camera not connect.
2018-8-16
SparkYeL
Philippines
Jakab Gipsz Posted at 2018-8-16 13:10
hi, i have tried different camera whic is working also but still have the same error. is it possible that the board is the problem?
2018-8-16
SparkYeL
Philippines
Joller79 DK Posted at 2018-8-15 10:17
hi, i already tried different micro sd too. and still problem. as you can see on the screen recorder the problem is intermittent live feed. which i know it is still working.  but there is a something not functioning correctly.
2018-8-16
Greg F
Flight distance : 944308 ft
Encoder error & Camera Error sounds like an Internal Hardware issue.   You can try re calibrating everything and update Firmware..  In the end best to send it in to get it looked at by DJI..
2018-8-16
Jos A
Flight distance : 73209 ft
downgrade app to 4.1.15 sees of this help
2018-8-16
SparkYeL Posted at 2018-8-16 20:56
Hi, if you manage to exhaust the possible troubleshooting steps then it would be better if you will consider the advice from DJI Susan which you'll be needing to send the unit to our facility so that our team can be able to evaluate the spark and fixed it for you. Please don't hesitate to reach us in any case you need our help.
2018-8-17
Alex Batalov
Flight distance : 24101106 ft
If the downgrading to 4.1.15 won’t help, then I’m afraid it is a hardware issue and the only thing to do will be to send it in to DJI.
Safe Flying.
Alex.
2018-8-17
