How many satellites fixed would be safe for the Mavic air?
5122 10 2018-8-19
djiuser_3jPJpGMEU6D6
Hi everyone! I'm a newbie. I just wanted to know what's the minimum number of satellites locked for a safe flight of the mavic air?
2018-8-19
G_Sig
Flight distance : 9109311 ft
Iceland
11 is what you should bee looking at.
2018-8-19
Oh! Thanks buddy. Will test that out.
Can anyone from India respond? It would be helpful.
2018-8-19
Flybee
Flight distance : 2203983 ft
djiuser_3jPJpGMEU6D6 Posted at 2018-8-19 12:52
I would agree with G_Sig about the number, I don't think the location matters, if thats what you are looking for when you need answers from India.
Happy flying with your new Drone
2018-8-19
Thank you!
Yeah that's what I meant. I've heard that max we get here is about 7. Wanted to check that out, but it's raining like crazy. Waiting for the rain to stop.
2018-8-19
Flybee
djiuser_3jPJpGMEU6D6 Posted at 2018-8-19 13:00
Thank you!
I think the Air have "access" to two sat systems so I think you will be able to get more then 7.
Try to start it up under some cover and see how many you get, don't mean that you have to fly.
google sat coverage for india, and see what the maps say, Don't know where in India you are located and it is a HUGE country so.....
Best of luck.
2018-8-19
Hi there, thank you for reaching out. Regarding your question just like what the previous post yes 11 or more and also make sure there will be no source of interference on the area for you to have a smooth flight with your Aircraft.
2018-8-19
Monk32
Flight distance : 50915 ft
Hi
In trigonometry you got to have at least 3 points of reference to actual find your position with accuracy.
In theory this is enough. But never rely on that when flying.
So to answer to your question, the minimum number of satellite signals for a safe flight is 8. Normally in most  places of the world you got to have 10 to 18.
The major problem of the satellite receiving signals is around equator in which the usual number is about 7 to 12.
You must lock at least 8 signals because it is possible during flight to loss signal from a satellite that is going to move under horizon  ("satellite sunset") or to face some signal separation issue, caused by a very close satellite line of sight trace, witch does not giving a clear signal to your receiver. Even an atmosphere electric anomaly (caused by ionosphere influence)  may infect satellite receiving on the system.
So with 8 satellites you can fly safely. Les than that I personally prefer not to.
2019-9-25
selo
Flight distance : 715807 ft
Turkey
Turkey 20 GPS sattalite
2019-10-27
morrisdl
Flight distance : 64524 ft
I like to see at least 9.  The GPS sats are at Medium Earth Orbit (MEO) about 12,000miles / 20000km.   They all circle the earth about twice per day, so it good to have more that 3.  If one or two drop over the horizon, you want to have sufficient backups.
2019-10-30
Aviationman123
12 Satellites is the minimum that I used
2019-10-31
