Controller phantom 4pro ERRO
1645 18 2018-2-1
fansa9b52cdb
Flight distance : 4255128 ft
Vietnam
Help me help me
please!!!
2018-2-1
Nebuchadnezzar
Flight distance : 3462946 ft
did it happens after last FW update ?  to help you we need more data, mobile device, app version ?
2018-2-1
fansa9b52cdb
Vietnam
Nebuchadnezzar Posted at 2018-2-1 10:09
I'm using the latest version app, ipad ios 11.2.5, dji go 4 version 4.2.5
Controller can not connect, It displays purple lights
2018-2-1
Nebuchadnezzar
Have you tried to reinstall the app ?
2018-2-1
Nebuchadnezzar
What about Firmware Update ( FW) ?
2018-2-1
fansa9b52cdb
Vietnam
I tried but failed, i'm using iphone 6s plus and ipad air 2
2018-2-1
fansa9b52cdb
Vietnam
2018-2-1
Nebuchadnezzar
lot of people getting the same problem ..
2018-2-1
Aardvark
Flight distance : 384432 ft
Edit:- Looks like RC needs to be relinked to aircraft.
Edit 2:-
2018-2-1
fansa9b52cdb
Vietnam
I tried but failed
help me
2018-2-1
lannes
Flight distance : 4465 ft
Have you tried using DJI Assistant 2 on the PC to upgrade/refresh the AC firmware first, this may help the controller upgrade
2018-2-1
fansa9b52cdb
Vietnam
it does not work @@
2018-2-1
It looks like that the firmware update is not successful. Please refer below and try to reset the RC: Turn off the RC, hold the C1, C2 and Record button at the same time, then turn on the RC, and connect it with APP to update from overall status. Make sure the update is successful, and link RC later.
BTW, the standard P4P RC does not support to upgrade via DJI Assistant 2, so it is normal to get the message.
2018-2-2
fansa9b52cdb
Vietnam
thank you, I will try again tonight
2018-2-2
fansa9b52cdb
Vietnam
DJI Susan Posted at 2018-2-2 00:26
I tried but failed
2018-2-2
Sorry about this. Please kindly start a case and send it in: https://www.dji.com/support The local team will take care once it arrived.
2018-2-5
Raul_Mtz
Mexico
Try (Aircraft must be off):
Press C1, C2 and Shutter (is in the right side next to the antena) button of the controller and then turn off the controller.
Don't release any button. IMPORTANT
Turn on the controller.
Release all buttons.
Then purple light must become a red light.
Then turn on aircraft.
2018-8-22
rwynant V1
Flight distance : 4842277 ft
Hey Raul,  I just did this same thing in another OLD thread.......this thread is from February.....
Randy
2018-8-22
SWP 1
Have you tried re linking the drone to your controller? Simple enough if that is the problem. Turn on both the drone and controller then push the two button under the controller and the record button at the same time until the red light turns blue and starts to bleep. Then go to the drone and with a pen or tooth pick depress the small red light between the SD card slot and computer link plugd it will start flashing and then link. Hope it helps
2018-8-23
