BobBob
![](https://forum44.djicdn.com/data/attachment/common/65/common_11_usergroup_icon.png) lvl.2
Peru
This is a very good article on batteries.
One missing topic here is, regarding point 2. Critical Low Battery Level Warning :
DURING A **FULLY AUTONOMOUS MISSION**, what will the drone do in this case, **if the Smart RTH function is turned off**.
If the smart RTH is on, it will abort mission and will RTH immediately. **But... if the function is off? **
It is not easy, becasue you do not know what is on the brain of the chubby programmer of DJI. And that is embedded in the firmware! (according to Litchi, it is encripted there).
And **WHEN** will it do it (whatever it be)? Suppose that you are much further than 2,000 meters from home point (DJI's firmware limit).
Will the drone continue the mission till it get the intense critical low battery level signal and will land mandatorily?
Or first, at the critical Low battery level, it will do one out of two things (following YOUR instructions defined before take off)? 1)Will it Hover 2)Will it Land? (Assuming that you selected one of this).
This last paragraph is very important.
Till now nobody knows the answer ![](//forum44.djicdn.com/static/image/smiley/default/smile.gif) |
