Cetacean
![](https://forum44.djicdn.com/data/attachment/common/4e/common_26_usergroup_icon.png) Captain
Flight distance : 2528264 ft
Sayhelloforme Posted at 2018-8-31 16:35
Thanks for all the replies. The tunnel box and hood is a good idea. I am using a p3p. What kind of device do you use. Since no one mentioned a difference between the mini4 and mini 2, it does seem no matter what device I use, I’ll still have the same problem. Unless Crystal sky of course. I fly a lot around Virginia Beach oceanfront and we don’t have trees on the beach for shade.
Aloha Hello,
Virginia Beach does have a boardwalk, are there locations you can go under the boardwalk for shade? Be sure to watch out for illegal behavior, they make movies and write songs about that!
You are right, you will need a sunshade solution. Measure the sides of your iOS devices so you have an idea of what you need (I only use Android). Also, are ports accessed on the sides? You will need to allow space for them. The diagonal measurement often used for screens only gives you enough information for identification, not usability.
Even CrystalSky screens (Android) can have visibility issues, but all visibility issues can be solved with the right design. Look at that nice DJI design for the CrystalSky sunshade noted above in Post #15.
When you need a portable shady spot, do not forget the Pup-Up Canopy. The 8X8 and 10X10 sizes really help reduce the brightness so sunshades work better. They can also keep you cooler in the sun. Unfortunately, it is more to cart around.
Hope this helps!
Aloha and Drone On! |
