Amateur Droner
Flight distance : 6411 ft
rsking Posted at 2018-4-6 20:09
I figured not at the same time,but I wasn’t clear . I didn’t want to get litchi and not be able to use dji go if I wanted to switch between the two.
I’m kinda new to flying drones and never flew it out of my sight. Would I benefit getting litchi? Someday I hope to be able to send it farther than I can see
Thank all
Yes you can still use the DJI app. You can use either one, just don't have the other one running in the background.
Get use to flying it, do figure eights and flying away from you then toward where you are (at first it can be confusing).Then use the ATTI mode to know what to do in an emergency, without all the safeguards of GPS and sensors.
In GPS mode the Phantom has brakes, holds position and will just hover in place if you let go of the controls, in ATTI mode it won't do all those things.
After you have that mastered, then you can think about missions on Litchi, take it slow.
Good luck and fly safe!
