Latest Software Update Fail
2933 11 2018-9-4
Phillby139
Flight distance : 52825 ft
Hi Evreyone,
I need some help...
Tonight i attempted to update my Mavic Pro with the latest firmware version... (V01.04.0500)
Usually i have had no issues with it at all..and i thought that it was taking much longer then usual.
The download of the update and the sending over the update to the Mavic went fine..until it got to the stage where it was installing it. The update got stuck at 57% for about 30 minutes... and then i got an error saying that the update could not be installed.. fair enough..so i tried again..same error.. so i connected my Mavic up to my laptop and did an upgrade with the DJI assistant 2.
Same issue..again...the update failed..
But to make things worse it has now completely wiped my Mavic of all previous updates and also the RC now wont link up to the aircraft..
DJI assistant is now saying i have version V00.00.0000 on my Drone!!
Can anyone suggest what i should do?
Thanks in advance
Phill
2018-9-4
Paul_IA
Flight distance : 4959019 ft
Have you tried doing a factory reset on the RC and drone (several videos on YT on how to do this)? Then try the update again.
2018-9-4
Aardvark
Flight distance : 384432 ft
Only thing I would suggest is try again with Assistant 2 on PC, ensure aircraft battery is fully charged (will not update if battery drops below 50%). Is the internet connection good, no firewall or virus killer interfering with operations (not usually a problem but perhaps worth considering).
Or is there another PC you could try. USB cable etc.
I updated mine yesterday; as no updates were being offered via DJI Go 4 I opted to use Assistant 2.
My Goggles and RC updated fine, then once aircraft firmware downloaded and transmitted to Mavic Pro my Assistant 2 shut down before upgrade started.  I re-launched Assistant 2 , and it was successful second attempt.
2018-9-4
Phillby139
Paul_IA Posted at 2018-9-4 03:57
Yup have tried all that, RC links up again which is good news but the updates still wont push onto the aircraft.
2018-9-4
Sorry for all the trouble. Please make sure to turn off firewall and antivirus software and the reinstall DJI Assistant 2. Kindly  restore the factory setting to factory defaults and then update the firmware. You can download the software using this link: (https://www.dji.com/mavic/info#downloads) and follow the video tutorial below. If it is convenient for you, kindly try to use a different cable or computer and the try again. Thanks for your support.
2018-9-4
Phillby139
DJI Paladin Posted at 2018-9-4 04:06
https://www.youtube.com/watch?v=HZE-fP28htI
Thanks for that!
Seeing as the drone has returned to V00.00.0000 can i just update my aircraft with the latest update and that will be ok or do i need to install all the old updates aswell?
Thanks heaps!
2018-9-4
Paul_IA
Just install the latest update. No need to install older ones unless you're trying to roll back to a specific version.
2018-9-4
Phillby139
Paul_IA Posted at 2018-9-4 04:12
Great! Thanks so much for everyone's help! I will give it a go!
2018-9-4
Phillby139 Posted at 2018-9-4 04:09
Thanks for that!
You're welcome. As mentioned above, no need to install the old firmware. Please keep us posted, thanks!
2018-9-4
Phillby139
Problem Fixed!!
Thank you, thank you for everyone's help!
2018-9-4
wwwili
Finland
Hi everybody,
I tried to update my Mavic Pro with DJI assistant 2 and it failed. For the third time it downloads ok, updates ok until freezes to 100% still "Updating". After 30min nothing has happened.
2018-12-9
wwwili
Finland
wwwili Posted at 12-9 10:24
Hi everybody,
Problem solved.
I needed to update the DJI Assistant 2 to higher version 1.2.4
2018-12-9
