Problems connecting white goggle with Mavic Pro 2
2775 12 2018-9-4
djiuser_2HKPfCFnaUaz
Flight distance : 58819 ft
All firmware is updated, goggles show mavic pro (and also mavic 1) for linking. When the pairing button on the mavic 2 is pressed it does not pair (and the connection to the remote is lost). I tried multiple times, various switching on and off sequences, no success.
What to do ?
2018-9-4
DennisMurry08
Flight distance : 5948264 ft
Did you go into the menu in the goggles and select link goggles? Then Mavic2 and then confirm? You probably did but you do that then hit the link button on MP2...mine linked in about 20 seconds...hope you get it resolved
2018-9-4
DennisMurry08 Posted at 2018-9-4 21:40
I went in the goggles menu and pressed link (it showed Mavic Pro, Phantom Pro and Mavic 1, I chose Mavic Pro), then pressed confirm, pressed the linking button on the MP2  and pressed confirm again, then the connection to the remote got lost and the goggles tried to link, however in vain.
The MP2 got updated via the iPhone not the DJI assistant.
2018-9-4
DennisMurry08
Just to confirm..you said Mavic Pro, PP and Mavic 1....I’m assuming Mavic Pro is the Mavic2 Pro? I don’t know what goggles you have but the version for RE is .0600 and for the Standard (white) it’s version .0500. Did you download the right version?
2018-9-4
I am using the white goggles not the RE. I repeated why the menu in goggles said and what I was a also a bit puzzled, it said Mavic Pro, PP and Mavic 1, however this only after the update to version xxxx.0500, which I did yesterday, so I was assuming this is ok.
2018-9-4
DennisMurry08
djiuser_2HKPfCFnaUaz Posted at 2018-9-4 23:36
I would plug your goggles back into to the Assistant and hit refresh. See if loading it again would help. After that I’m out of ideas..
2018-9-4
DJI Natalia
Hi, sorry for the inconvenience caused. Can you please try to refresh the firmware of your DJI Goggles via DJI Assistant 2? After that, please try to connect again. Thank you.
2018-9-5
I tied everything (refreshing all components from the assistant 2 (except the remote control) still the same issue
2018-9-5
DJI Natalia Posted at 2018-9-5 08:11
Any other suggestions?
The selection menu in the goggles does not say explicitly Mavic Pro 2, it says Mavic Pro and further down Mavic 1, is this what it is supposed to be?
2018-9-5
Your reply helped me solving it and there is a bug: I am running the goggles in German language, when I set them to English, it says Mavic II in German language it says Mavic I in the same place.
I will try to connect now !!!
2018-9-6
it works now, what pain and stupid bug!!!!!
2018-9-6
potsy1968
Flight distance : 26811 ft
djiuser_2HKPfCFnaUaz Posted at 2018-9-6 11:31
I purchased a pair of used DJI Goggles and cannot get them to pair with my Mavic 2 Zoom.  Can this be done.  I've searched the internet for solutions and can find nothing.
2020-3-31
DennisMurry08
potsy1968@yahoo.com Posted at 3-31 17:04
Which ones did you get..the white ones or the black RE? Either way connect the assistant and make sure the goggles and your zoom is updated. Next turn on your zoom. There’s a bind button you need to touch..I use a paper clip. Have your goggles already powered up when you do that. Go to settings and you’ll see the bind option. Make sure you choose the M2. Then choose yes (I’m going off memory) and it should take about 10-15 seconds and it will say finish. Touch the back button under the goggles..I think it’s like the back button or f2 button...it gets you out of the setup. You should be done..I’m not sure if the black RE is the same but that’s how it works on the white ones.
2020-3-31
