DJI Natalia
Hi there. Thanks for the inquiry. The Phantom 4 Pro V2.0 uses the same camera as the Phantom 4 Pro and is equipped with a 1-inch 20-megapixel sensor capable of shooting 4K/60fps video at 100Mbps. Also, like the Phantom 4 Pro, V2.0 features a 30-minute maximum flight time and 7-kilometer long-range control. The remote controller of the Phantom 4 Pro V2.0 also supports 2.4 and 5.8GHz frequency switching, and a remote controller a with built-in screen is also available. Different from the Phantom 4 Pro, the Phantom 4 Pro V2.0 is equipped with an OcuSync transmission system, which allows the drone to connect to DJI Goggles wirelessly. The Phantom 4 Pro V2.0 also features an upgraded propulsion system with FOC sinusoidal driver ESCs and 9455S quick-release propellers that reduce noise and make the drone more aerodynamic. *The remote controller of Phantom 4 Pro V2.0 is not compatible with the Phantom 4 Pro, which uses Lightbridge transmission. Other accessories such as batteries, chargers, and ND filters are compatible with both the Phantom 4 Pro and Phantom 4 Pro V2.0. Should you have further question, please let us know. Thank you. |
