Mavic 2 pro is suddenly sliding to the side
1615 12 2018-10-22
djiuser_2jc8LWvY4Qg6
Since I bought the drone the Mavic was staying in the air almost exactly with no sliding.
Since yesterday I noticed a slide to the right side (about 30 cm), this happened with out any wind and just some meters above the ground.
I just checked it then at about 50 m over the ground and I still saw the sliding. When I leave the sticks alone, the Mavic moves slowly to the right, you also can observe it via the app if the crossfield in the center is enabled. I just changed the propellers but with out beeing a solution.
I recalibrate Imu and Compass. Any thoughts?
Thanks!
2018-10-22
FlyDK
Flight distance : 1636286 ft
Try calibrating the RC as well, and then relink it to the AC.
2018-10-22
Hi, thanks for reaching DJI Forum. We do apologize for the troubles you had recently. Have you seen some error messages before you took the flight? All firmwares are updated? I would highly suggest to calibrate the remote control and kindly let us know what will happen. We're here to help you. Thank you.
2018-10-22
Thanks for the quick answer. I also did the rc calibration but the issue is still there. Firmware is updated and I didn't get any message before the sliding started. But you will see the sliding on every flight.
2018-10-22
djiuser_2jc8LWvY4Qg6 Posted at 2018-10-22 04:11
Hi, does it have the latest firmware already? It should be v01.00.01.00. I will be providing a video tutorial on how to update the firmware just in case you haven't updated it yet. Should you have any concerns, kindly let us know. We're here to help.
2018-10-22
Ben Mason
Flight distance : 610614 ft
Hmm, so are you saying the drone drifts 30cm to the right and stabilises or it just constantly drifts right but at a very slow pace? Also just to confirm is the drone actually moving or is it just the camera that is moving slowly ?
2018-10-22
Firmware is up to date. The drone is constantly moving to the side (mostly right, but also left) with a very slow pace. It is not the camera, I double checked that. Could this be some issues with the side sensors?
2018-10-22
Ben Mason
It's difficult to say, if you had a flight log from your phone i could look at that and it may tell me more. Without that or looking at the drone myself i cannot really say. I doubt it's an issue with the side sensors, if it was you could just switch from T to P mode to find out, though i don't think you were flying in T mode in the first place were you ?
2018-10-22
No, most of the time I use P. Will again do some Imu calibration and then come back with a log. Thanks!
2018-10-22
msinger
Flight distance : 228255 ft
Can we look at one of your flight logs? If so, please upload it here and post the link back here.
2018-10-22
Sure will upload one tomorrow! Thanks!
2018-10-22
dronist
Dude, post a short video. Also 30cm sliding, is it back and forth or sliding to one direction? how many stats and is the bar green ready to go with enough stats?
2018-10-22
Blellow
Flight distance : 1311056 ft
Try flying higher that should fix it.
2018-10-22
