New Mavic 2 Pro/Zoom Firmware Released(2018.10.11)
DedeMavic Posted at 2018-10-20 06:30
Another video showing the issue while flying
Issue while flying
Well received. Could you connect the aircraft with DJI Assistant 2 and export the corresponding flight data? You may refer to the below screenshot and confirm.
2018-10-21
Jose C. Borrero Posted at 2018-10-20 06:46
Well, I spoked too early. Yes, I crashed the mavic in my garage. It got confused. Did not reconized were to avoid the garage door. Only minor scratch on the lateral propeller at 2 foot height.
Hi Jose, I'm so sorry to read the crash. Please kindly check whether there is obvious damage to the drone and replace the propeller to check. If the unit needs to be serviced, please kindly contact our support here for further assistance: https://www.dji.com/support
2018-10-21
fans57730651 Posted at 2018-10-20 21:56
Hi team, my upgrade to latest version failed and so can't update using assistant 2 as well.... Its failing at 24% my dji account is seelamashok@gmail.com please help...
Sir, we're sorry to read the troubles. Just to verify, is there any error message when the firmware failed? If not, please kindly offer the screenshot and upgrade log for further assistance, thanks so much!
Assistant 2(Windows) C: /Users/XXXXXX/AppData/Roaming/DJI Assistant 2/upgrade_log
Assistant 2(MAC): ~/Library/Application Support/DJI Assistant 2/upgrade_log
APP(IOS): Click the DJI logo on the left upper corner more than 10 times, you will see the log and copy it to us
APP(Android): dji/dji.go.v4/log/cache/up_new_all
2018-10-21
Peo93 Posted at 2018-10-21 13:09
thank you very much
I have started the case
My pleasure. If there is anything else we can help, feel free to contact us.
2018-10-21
Akossss
Flight distance : 1478350 ft
DJI Susan Posted at 2018-10-19 01:34
Hi Akossss, may I know which mobile do you use and what's the current App version? You may clear the cache or reinstall the App to check. If the issue persists, please kindly export the upgrade log( dji/dji.go.v4/log/cache/up_new_all) for better assistance, thanks!
Thanks, I've done the upgrade using the Assistant 2,next time I'll reinstall the app before upgrade... By the way it was a Samsung Galaxy S9+...
2018-10-22
Akossss Posted at 2018-10-22 01:16
Thanks for the clarification. So, the firmware update is successful via DJI Assistant 2, but failed on Samsung Galaxy S9+, right? We're still collecting the data to locate the exact reason, any feedback will be appreciated.
2018-10-22
Jose C. Borrero
Flight distance : 1170768 ft
Puerto Rico
bernardren07 Posted at 2018-10-20 10:45
Oh no. Better PM to dji and send your log data to them. See if tech can fix your hardware restore with BETA firmware or not.
how I do that? Also need to confirm the sensors doesn't work at night, same as others.
2018-10-22
Vendex
Flight distance : 16722920 ft
Bulgaria
Jose C. Borrero Posted at 2018-10-22 08:37
It's normal, sensors need light, except 3d infrared sensors ;)
2018-10-22
windsurfkruzer
Flight distance : 186535 ft
Hi All.
I have a Mavic 2 Zoom with the latest firmware release here mid Oct. V01.00.0100 And Android Go 4 Ver 4.3.2
I have tried different Phones and batteries with no change to the below..
I get the "Temporary Obstacle Avoidance" error when in Active Track and try to engage "Spotlight" mode. Just after drawing the Square or selecting the green circle.
The Mavic still tracks at the subject whilst staying stationary, as well allowing me to also fly the Mavic around (although appears to be in a Course Lock type mode).
Just curious if this error is related to the other complaints her
Also I seem to be missing the option to set my C1/C2 button for "Toggle Map/Live" view.
Will this be available again in an update??
2018-10-22
Hi Jose, the vision system and infrared sensing systems have the corresponding working conditions, you may refer to page 22 of the user manual: https://dl.djicdn.com/downloads/ ... 20Manual%20V1.4.pdf
2018-10-23
windsurfkruzer Posted at 2018-10-22 21:28
Hi All.
Hi there, may I have a short screen recording of the "Temporary Obstacle Avoidance"? Please also include the missing options of "Toggle Map/Live", we'd like to check the exact status, thanks so much!
2018-10-23
Paul Robertson
Really cool info, thx
2018-10-23
Future Shock Visuals
Flight distance : 56211 ft
where do I get DJI Assistant? what is the difference between updating via the app/assistant?
2018-10-23
DedeMavic
Flight distance : 649403 ft
DJI Susan Posted at 2018-10-21 19:53
Hi Susan.
I went into DJI Assistant and clicked at the report data file.
It said information submitted but then asked me to add files. I just closed at this point.
Did I do it correctly? Pleas advise if I missed something.
Thank you!
2018-10-23
yuft gtdr
Egypt
100% Agree with you!
2018-10-23
Pavel.Donev
Flight distance : 1004383 ft
Already several times the radar shows more than 6 meters while the dron is on the ground! On landing it does not measure the distance to the ground. Please pay attention to this error in the next update!
2018-10-23
windsurfkruzer
DJI Susan Posted at 2018-10-23 00:29
Hi there, may I have a short screen recording of the "Temporary Obstacle Avoidance"? Please also include the missing options of Toggle Map/Live", we'd like to check the exact status, thanks so much!
Hi Susan.
PM sent with YouTube link.
2018-10-24
DedeMavic Posted at 2018-10-23 11:56
Hi Susan.
Please kindly tick the corresponding date and save to local, then upload the files to Google Drive or Dropbox and share us with the link, we'd like to forward to our engineers for review.
2018-10-24
Pavel.Donev Posted at 2018-10-23 20:40
Hi Pavel, could you clarify which data do you refer? Is it the one I marked? Sorry, I'm a little confused...If yes, it is the distance that the forward sensors/backward sensors detected the obstacles, could you confirm?
2018-10-24
windsurfkruzer Posted at 2018-10-24 00:10
Hi Susan.
Received with thanks! I'll forward to our engineers to check and will come back as long as there is an update.
2018-10-24
DedeMavic
DJI Susan Posted at 2018-10-24 00:45
Here you go!
Log
2018-10-24
ParideM
Flight distance : 6103757 ft
Hi, this happened after last Firmware V01.00.0100. (Samsung S8plus connected by factory short cable from controller lateral microusb port to C (smartphone))
I gone flight near an observatory and maybe there had great interference issues, so ok maybe was normal loose connection when drone was at 3-8mt from controller. But to the end of the flight the famous message:
Take a look:
- Controller connection error under 10mt go to 4:16, 5:30 and 12:50. I remember when I bought the drone and no firmware update installed yet, I could not conect controller to lateral port, i had to connect by usb port under the controller, maybe is this? You have to optimize yet?
- Obstacle avoidance temporary error go to 14:20 what abaut?, you can see distance from observatory too.
- Active track working well 6:00.
2018-10-24
Thank you! I'm downloading the file and will forward to our engineers as soon as it is finished.
2018-10-24
ParideM Posted at 2018-10-24 11:57
Take a look: https://youtu.be/mbg8HJeF_EI
Hi ParideM, thanks for reaching us. For the Remote Controller Connection Error, could you export the corresponding flight data in the aircraft and log in the RC? I'd like to forward to our engineers to review.
As for the obstacle avoidance temporary error, this is normal as the obstacle avoidance will not work in landing mode, please kindly note and understand.
2018-10-25
rutacrew
Flight distance : 335413 ft
When I landed before the update there were never any errors regarding the sensors. What does it mean that the sensors do not work during landing ? There is no precise landing and  the senses turned off? When are you going to release the corrected firmware ? Now is more than two weeks.
2018-10-25
ParideM
What happen?I can't read log data of the my Mavic Air too....
I download flight record from Airdata but I can watch it on DJI Assistant.
2018-10-25
Pavel.Donev
Bulgaria
When capturing 360 panoramas, gimbal turns off and stops shooting! Please review the video and tell me if the problem is in the software or do I have a gimbal defect?
2018-10-26
Pavel.Donev
Bulgaria
DJI Susan Posted at 2018-10-24 01:16
https://youtu.be/vt6e1Qde4p4
Here's what I'm talking about!
2018-10-26
Leberkasbepi
Flight distance : 42110 ft
Austria
Have anyone problems with the image quality? After update my mavic 2 pro, the images are complete blurry, but only in manual mode. "S" or automatic works, video to.
2018-10-26
henley
Flight distance : 41650 ft
Pavel.Donev Posted at 2018-10-26 01:20
When capturing 360 panoramas, giGimbal error.mbal turns off and stops shooting! Please review the video and tell me if the problem is in the software or do I have a gimbal defect?
Could be that the wind is too strong, hitting the gimbal and overworking its motors? While it might not seem very windy on the ground, it can be very different above. Do you have the same issue when shooting 360s in low wind conditions where the notification to land asap due to wind isn't on the screen?
2018-10-26
rutacrew Posted at 2018-10-25 04:57
Hi rutacrew, vision Systems are disabled during landing, this has been made clear in the user manual, you may refer to the below screenshot to check. https://dl.djicdn.com/downloads/Mavic_2/Mavic%202%20Pro%20Zoom%20User%20Manual%20V1.4.pdf
2018-10-26
ParideM Posted at 2018-10-25 04:59
I download flight record from Airdata: https://drive.google.com/open?id=1_P1YqGpfIlX9-JFbUf1iknJcxhHLprYt
Thanks for getting back to us. I'm afraid that the flight record is not enough to locate what's the exact status at that time. May I know what's the OS of your PC? Please try to reinstall the right DJI Assistant 2 from the corresponding product page and check again: https://www.dji.com/mavic-2/info#downloads
You may also change to another working cable to verify.
2018-10-26
Pavel, upon checking your video, it seems that the gimbal was shaking in the wind, you may test in no wind environment. As you mentioned that the gimbal turns off and stops shooting, but I do not find these in this video. I'm not sure if there is any misunderstanding between us, it will be better to offer the right video and corresponding flight data in the aircraft for further analysis, thank you!
Also, for your another video, Downward Obstacle Sensing is not functioning as the height is 153m. Please kindly note that the downward vision system works best when the aircraft altitude is 0.5m to 11m. During the landing period, the VPS on the bottom changes according to the altitude, that's to say, the VPS works at that time, no worries.
2018-10-26
Leberkasbepi Posted at 2018-10-26 12:48
Hello Leberkasbepi, please try to refresh the firmware and see whether the blurry images remain. If no luck, please kindly upload some original videos in the SD card for better assistance, thank you!
2018-10-26
Pavel.Donev
DJI Susan Posted at 2018-10-26 20:34
At the end of the first video it is very clear how the gimbal shakes and hangs in the air! The other video clearly shows that the sensors glow red and do not work even though they are launched even during the day!
You mean everything is normal! Why your online support has been out for two weeks now! I'm already uploading flight logs over the application several times! I still have no answer from you! After you had a conversation with your employee, you had to contact me on a phone! I do not have a call from you! The only place where problems with your test model can be shared is here!
Here's another problem! When returning home, the plane stops and leaves! It reaches 36 kilometers per hour and stops then goes again! Is this also normal? He can not develop more than 40 kilometers per hour in flight and return home!There is no wind but the gimbal is rolling again! This camera is too big and heavy for this gimbal! That's why he can not stabilize!
2018-10-26
Hi Susan.
Update: I just got an update from our engineers that they need the corresponding flight log in the aircraft for further analysis, could you refer to the screenshot in 361# and export the data file? Thank you!
2018-10-26
rutacrew
I have the same problems as you, Pavel. But Sussan thinks it's normal that an error message pops up. Strange that there is a error once landing and sometimes there is not. During the flight, the sensors are red, but apparently normal according to DJI. Please Can you write what system are you use. IOS or Android. I have these problems on Samsung S9+. Cheers
2018-10-27
Pavel.Donev
Bulgaria
rutacrew Posted at 2018-10-27 00:04
I use Android! I'm not bothered by the error about the sensors, they will not work before the next update! We claim that the camera can not stabilize and that the droning on the return home permanently stops and leaves! One flight of water can stay there! See the end of the return home video.
Apparently DJI overlooks the owners of Android devices! For unexplained reasons they obviously have a deal with the apple!
2018-10-27
Leberkasbepi
Austria
DJI Susan Posted at 2018-10-26 20:39
Firmware refresh solve the issue. Thanks!
2018-10-27
ParideM
DJI Susan Posted at 2018-10-26 18:46
I tried to reinstall the correct version V2.0.2, I tried to link with DJI cable and with GoPro cable, no data.
What's happened ?  I have MacOS Mojave 10.14
2018-10-27
