Introducing DJI Flight Simulator
1984 11 2018-10-30
Aaron Avila
Reprint
Content shared by I Can't Walk But I Can To Fly Drone Show
2018-10-30
Haggi
Flight distance : 2581785 ft
I hope I can run the simulator with a Spark RC.
Thanks for sharing, Aaron!
2018-10-30
Hello Aaron Avila. Thank you for sharing this DJI Flight Simulator video to us and for your support. Have a safe and happy flying.
2018-10-30
A CW
Flight distance : 14754314 ft
Wow - that looks cool - I'll have to try it out!
2018-10-30
jacksonnai
Malaysia
Thanks for sharing sadly it does not work with spark rc
2018-10-30
rdsb
Flight distance : 236230 ft
Problem with my Mavic Air Rc :
When plugged to the computer, windows tries to mount a usb and a com port, and beeps.
- 1 These 2 peripherals get an error, probably due to a driver issue, are unmounted -> second beep 10 seconds later
- 2 Windows tries to remount those 2 peripherals -> another beep 10 seconds later
- 3 Back to 1
I tried 3 different cables : same problem
I tried to connect the rc to usb2 and usb3 ports : same problem
I tried to connect the rc with the middle Usb port : no rc detection at all.
I tried restarting my computer : same problem
The Rc is never detected as a valid usb peripheral.
Using windows 10 pro version 1803 (redstone 4)
Dji assistant is working fine if I connect my drone.
2018-10-31
optimaforever
Can't connect to Mavic Air RC too... Very strange, I tried to update the driver with the latest DJI Assistant but no luck.
2018-10-31
fans895ce914
How to ARM the drone with Keyboard??
Can't use my Mavic Pro RC.
2018-10-31
WillThib
I tried to connect with my mavic 2 pro RC but it doesn't work. Any help ?
2018-10-31
Aaron Avila
Sorry can't help, I only found and shared content.
2018-10-31
rdsb
Hello DJI.
The drivers for Mavic Air are working with DJI assistant 2 1.07
See post 13 of :
https://forum.dji.com/forum.php?mod=viewthread&tid=134139
Unfortunately, you have removed all links to this version of DJI assistant
See post 34 of
https://forum.dji.com/thread-79642-1-1.html
Could you please give us a link to this assistant ?
Thanks in advance
2018-10-31
rdsb
To solve your problem, please download the drivers here :
https://www.dropbox.com/s/hvgmk8j52vnegmk/DJI_Driver_Installer_32bit%2664bit.exe?dl=0
WIndows 10 will mount the CDC acm data and the com port as a usb serial device.
This also solves dji assistant unable to connect to mavic air  !
2018-11-1
