Lost connection with no warning and 25m distance
2496 44 2018-11-1
Ryanwalexander
Flight distance : 110177 ft
Indonesia
Fortunately there was no damage as it was trying to land so I was able to just grab it out of the air.  Best possible scenario given the drone failure but I want to know how to prevent it from happening when I'm not right next to it.
I noticed it was pretty hot and also got pretty hot when downloading the .dat file.
I've downloaded the .dat file to figure out why but it's encrypted.  Can someone help me?
2018-11-1
Ryanwalexander
Indonesia
Note that the file from DJI GO doesn't have any useful details as it stopped recording when the drone lost connection.  Everything looked normal on its log file.
2018-11-1
AlexPapadas
Flight distance : 93235 ft
Unfortunately i have face the same once.Could you upload   your flight details ?
2018-11-1
Ryanwalexander
Indonesia
Here's the log from my phone:
https://www.phantomhelp.com/logviewer/SY9FPRH1N925OG1R96QJ/
2018-11-1
Hi Ryanwalexander, we're sorry for reading your post. Just to verify, is there any obvious damage on the drone? You may connect with DJI GO 4 and check if there is an error message.
For the lost connection, you may export the flight records, corresponding flight data in the aircraft and log in the RC, we'll forward to our engineers to check the exact status, thank you!
2018-11-1
Ryanwalexander
Indonesia
DJI Susan Posted at 11-1 02:56
Thanks for your response.  No damage to the drone fortunately - it's never been crashed or mishandled.
I tried exporting the .dat file from the AC and uploaded it with Assistant 2 - can you confirm that it happened correctly.  I'm not sure how to do the same with the RC.  Is that just the synchronize function in the app?
I already posted the flight log as you can see above.  Instructions would be really appreciated!
Thank you,
Ryan
2018-11-1
JJBspark
Flight distance : 12717890 ft
Hi Ryan,
Nothing abnormal in this flight record.
It stops with your MA at a height of 22.9 meters.
You said you grab it out of the air....but how at that height?
I think only your mobile device was disconnect from the RC but you were in control using the RC.
cheers
JJB
2018-11-1
Ryanwalexander Posted at 11-1 03:18
Thanks for getting back to us. For the DAT files, it is recommended to export and upload to Google Drive or Dropbox and share the link with us. Regarding the flight records, we do not support to analyze the data from the third party software, please kindly send us the original file for further follow-up, thank you!
For the RC log, please refer to the below screenshot and export the log, it will be ok.
2018-11-1
Ryanwalexander
Philippines
DJI Susan Posted at 11-1 19:10
Thank you.  I'll upload as soon as my internet is good enough.  Did the upload from DJI assistant not go through?
To answer the other question, I didn't grab it at 27m height - it was force landing and unresponsive to the RC so I grabbed it out of the air before it could crash into the uneven ground it was heading towards.
2018-11-2
Ryanwalexander
Philippines
DJI Susan, here's the link to the RC .txt files.  There were 3 of them and I don't have a way to tell which is which.  I've zipped them to reduce file size.
https://drive.google.com/file/d/ ... B1/view?usp=sharing
Please let me know if you can or can't access it in the shared link.
2018-11-3
Ryanwalexander
Philippines
Am I good to try flying again or should I not?
2018-11-3
Ryanwalexander Posted at 11-3 05:12
https://drive.google.com/file/d/11-FbIeXSNpcnIUEVHkktVd085puZ0gB1/view?usp=sharing
Received with thanks! It seems that there are only the RC logs, right? I'm afraid that the data upload in DJI Assistant 2 may not work well, we sincerely suggest to save the DAT file to the local and upload to share.
2018-11-4
Ryanwalexander
Philippines
DJI Susan Posted at 11-4 00:37
DJI Susan, here is the corresponding AC log.
here
I also downloaded a bunch of other files from gimbal, system, etc.  Let me know if you think those should help.
2018-11-4
Ryanwalexander Posted at 11-4 21:08
here
Received with thanks! I've forwarded to our engineers to review and will keep following up.
Also, it is not recommended to fly the drone for now as we're not sure the disconnection reason for now. Safety is always the top priority, thank you!
2018-11-5
Ryanwalexander
Philippines
DJI Susan Posted at 11-5 02:29
Hi there, any update?
2018-11-13
Ryanwalexander
Philippines
I want to add that every time I fly the drone it asks for a compass recalibration. It's a bit annoying and I didn't have this issue with any of the MPs that I used.  Is this normal for MA?
2018-11-13
Just got an update from our engineers that they need the System partition log of the aircraft. Could you refer to the below screenshot and check again? Thank you!
2018-11-14
jcflyer23
Flight distance : 4298 ft
I have asked this question before, once the signal is lost how does the drone know where is the home?
2018-11-14
jcflyer23
I have asked this question before, once the signal is lost how does the drone know where is home?
2018-11-14
Lucas775
Flight distance : 50642090 ft
Sounds like  you had it on land mode for lost of connection, try setting it to RTH for lost connection.
2018-11-14
InvisibleName 7
Flight distance : 795653 ft
jcflyer23 Posted at 11-14 04:30
By returning to the GPS location it recorded when it took off.
2018-11-14
jcflyer23
InvisibleName 7 Posted at 11-14 05:04
That's the part I didn't understand if the signal is lost how can it know where to go?
2018-11-14
Ryanwalexander
DJI Susan Posted at 11-14 02:46
One of these is the system log (along with all the others).  I shared links earlier but I don't think they were accessible.  Pasted again the same way that I did the first one.
Can you let me know if you can access it? I downloaded them all when I connected.
https://drive.google.com/file/d/ ... vf/view?usp=sharing
https://drive.google.com/file/d/ ... tv/view?usp=sharing
https://drive.google.com/file/d/ ... No/view?usp=sharing
https://drive.google.com/file/d/ ... so/view?usp=sharing
https://drive.google.com/file/d/ ... jd/view?usp=sharing
I'd love to see the contents of these files - is there a utility I can use to decode them? That would be much preferred over waiting to hear back from your engineers.
Thank you,
Ryan
2018-11-14
Ryanwalexander
jcflyer23 Posted at 11-14 19:33
If it loses GPS signal and RC signal it can't return home.  It is, however, able to use its internal GPS as long as it has GPS signal to fly back to the homepoint when it is set to do so after losing RC connection AND it is working properly.
2018-11-14
jcflyer23
Ryanwalexander Posted at 11-14 20:26
Ok now I understand and that makes sense, thanks.
2018-11-15
Ryanwalexander
jcflyer23 Posted at 11-15 04:27
NP.  You should take a look through the manual if you haven't.  There's lots of great info in it.
2018-11-15
neonadler
please link aircraft  to DJI Assistant 2 software, and export System LOG, send LOG to us for analysising, thanks.
2018-11-15
InvisibleName 7
Because the GPS Rx is in the drone, not the RC
2018-11-15
Ryanwalexander
neonadler@hotmail.com Posted at 11-15 04:49
It is uploaded and downloadable in post #23.  Were you unable to find it in there?
2018-11-15
jcflyer23
InvisibleName 7 Posted at 11-15 04:50
Now this make even more sense thanks!!!
2018-11-15
Ryanwalexander Posted at 11-14 20:11
Thanks for the clarification, I've forwarded to our engineers for review.
For the DAT files, you may refer to the tutorial from here: https://dl.djicdn.com/downloads/ ... +Tutorials+V1.0.pdf
2018-11-16
Ryanwalexander
DJI Susan Posted at 11-16 01:48
For the DAT files, you may refer to the tutorial from here: https://dl.djicdn.com/downloads/DJI+Support/Flight+Controller+Data+Analysis+Series+Tutorials+V1.0.pdf
Thank you but it looks like Assistant can't open Mavic Air .dat files because they're encrypted - or is there something I'm doing wrong?
What kind of timing can I expect on the analysis? This is becoming a significant chunk of time with a recommendation not to fly the drone.
2018-11-18
Ryanwalexander Posted at 11-18 09:03
I'm afraid that the encrypted data cannot be opened at your end. The engineers are reviewing your data, I'll keep following up as well.
2018-11-20
Update: Our engineers have been aware of the RC issue and they are trying to locate the root cause due to the low recurring probability. So sorry for the inconvenience.
2018-11-20
Ryanwalexander
DJI Susan Posted at 11-20 23:44
So you have determined it to be an RC issue. I would really appreciate more details.
This drone was a very expensive purchase for me and it doesn't feel good being told not to fly it by the manufacturer as my warranty period and resale value counts down minute by minute.
What can you do to rectify this?
Thank you.
2018-11-22
Ryanwalexander Posted at 11-22 01:08
Our engineers are working on it and trying to fix it by the firmware update, please allow them some time, thank you!
2018-11-24
Ryanwalexander
Vietnam
DJI Susan Posted at 11-24 01:06
Hello, following up again. Do you have an update?
2018-11-29
Ryanwalexander Posted at 11-29 02:17
Hi Ryan, I'm sorry that there is no update for now. We'll release it on our website as soon as it is ready, appreciate your support and patience.
2018-11-30
Ryanwalexander
Vietnam
DJI Susan Posted at 11-30 02:34
Did you see my post about the compass needing calibration every time I fly. Is that potentially a related issue? Is that normal?
2018-11-30
fansafdbea66
Flight distance : 181634 ft
I had the same problem yesterday. And around 35 to 40 meters I lost control of the drone. Luckily the drone did the go home automatically. But I was very worried.
2018-11-30
