Battery discharge setting
1339 13 2018-11-10
Gazmg
Flight distance : 195358 ft
Hi peeps if i set the battery discharge to say 3 days , do i have to put each battery in the drone to set it ie turn on change setting turn off,take battery out put next battery in turn on change setting turn off etc ? Thank you
2018-11-10
FlyDK
Flight distance : 1636286 ft
Yes, must be done for each battery.
2018-11-10
Gazmg
FlyDK Posted at 11-10 02:58
Thank you  for the info ...
2018-11-10
msinger
Flight distance : 228255 ft
You'll also need to reset this setting after installing new firmware on the batteries.
2018-11-10
FlyDK
Gazmg Posted at 11-10 04:10
You're welcome mate.
2018-11-10
Hello. Thank you for the inquiry. All of your battery's firmware needs to be updated so that your batteries will be compatible with your drone. Thanks for your support.
2018-11-11
Gazmg
All done thank you
2018-11-11
Gazmg Posted at 11-11 07:31
All done thank you
That's good to hear. If you needed any help, please don't hesitate to contact us. Cheers!
2018-11-12
AlansDronePics
Flight distance : 823163 ft
Guernsey
Out of interest, why do you think you need to change it?
2018-11-12
Gazmg
AlansDronePics Posted at 11-12 09:16
If i was to fly on the 9th day and they are due to discharge on the 10th day but i would charge them anyway before flying then i thought if they have discharged themselves then i can cycle them better ? No ?
2018-11-12
3 days is the right and best setting, but before flying it will do no harm if it’s say two days to pop on the charger to make sure fully charged.
2018-11-12
AlansDronePics
Guernsey
Gazmg Posted at 11-12 10:46
I personally see no harm in what you propose, i.e. the 3 day cycle, but then DJI probably did research to decide on the 10 day default.
Regardless of what day cycle you decide on, always pop them on charge before a flight having pressed and switched on the battery button and let the charger top you right up.
The control circuit will manage everything.
2018-11-13
Gazmg
AlansDronePics Posted at 11-13 04:19
? did you say turn battery on prior to charging or did you mean on then off then charge ?
2018-11-13
AlansDronePics
Guernsey
Gazmg Posted at 11-13 04:40
I assume the battery management will be similar to the phantom 3 pro I have as well as the Mavic Pro's. I expect someone will put me right, but when you switch the battery on, as if fitted to the drone, the charger senses it is on and actively switches off the battery, but charges for a short while. Whereas, if you just connect a 10 day discharge cycle battery to the charger after about 2 or 3 days, it shows it is fully charged and no further charging takes place.
I personally have found this makes an observable increase in flight time, but obviously no more than any freshly charged battery would. So don't think you get more power this way, just the full design capacity for its age and condition.
2018-11-13
