Tilt lock
2032 14 2018-10-8
Simone85
Could you relase a new firmware that include a TILT LOCK MODE ? I would like to have the possibility to work with the TILT and the PAN LOCK mode together.
Thank you.
Simone.
2018-10-8
Hi Simone, thanks for reaching DJI Forum. We do appreciate bringing this to us. May I know what is your aircraft? I am going to forward this to our engineers for a possible update but there is no guarantee. Please visit our product release notes on our official website.  Your patience is very much appreciated. Thank you.
2018-10-9
manshmedia
Flight distance : 50023 ft
Yeah I am also facing some problem not sure if it is tilt lock.  Basically in Ronin 1 when in handheld mode the camera use to to tilt up when rig was tilted up and down however with Ronin 2 I am unable to do that any suggestions
2018-10-9
manshmedia Posted at 2018-10-9 07:26
Hi manshmedia, please try to enable the Tilt axis in SmoothTrack, the device will react to the operator's movement without a remote operator.
2018-10-11
Hi Simone, if you would like to lock Tilt and Pan at the same time, please try to disable SmoothTrack of these two axes and enable the Roll axis to see if that is what you want.
2018-10-11
Simone85
DJI Mindy Posted at 2018-10-11 03:54
than for your reply.
next monday i'll try that and i'll let you know.
thank you.
2018-10-12
Simone85 Posted at 2018-10-12 12:11
You are welcome, please let us know if you have any further concern.
2018-10-12
Simone85
DJI Mindy Posted at 2018-10-12 23:41
It doesn't works because if I torn off the tilt smoothtrack and I lock the tilt motor, the R2 say tilt error in the screen.
I need a new firmware that permit to work whit the tilt lock exactly like the pan lock works.
2018-10-15
Simone85 Posted at 2018-10-15 08:22
Thanks for getting back, your request will be forwarded to our engineers for consideration in the future development, thanks for your attention.
2018-10-16
manshmedia
Thanks Mindy but ain't reacting as it should in my DJI app I see smoothtrack and then a slide button of tilt. Can you recommend tilt settings like sensitivity deband etc.
2018-10-21
manshmedia
This is the problem it doesn't tilt or react to movement even in smooth track
2018-10-21
manshmedia
This setting on top left of battery panel solved it what option is this
2018-10-21
manshmedia
The problem is solved but new problem is that the Ronin remote is no longer functional I mean stop start button as soon as I start remote it exits this mode. Any solution
2018-10-21
Simone85
manshmedia Posted at 2018-10-21 02:51
Unfortunately if you use the FVP mode you'll have reactive tilt and pan but you'll lose the level beacause the roll doesn't work.
I need to keep the level and to have tilt and pan reactives.
2018-10-23
LUMINARIO
Flight distance : 169925 ft
I second that request - more options make for a more solutions in the field!! thank you for posting!
2018-11-27
