Tried a Litchi Mission that was impossible to fly manually.
1151 28 2018-12-3
Bing Err
Flight distance : 9249964 ft
So heres the mission. I've tried it before manually and everytime I fly behind the water tower I lose signal and initiate RTH. I'll post the mission first and then my video discussing the mission and a split screen of 2 attempts with the Mavic Air and 2 with the MPP. MPP was far more stable and smooth.
2018-12-3
Sky Carrier
Flight distance : 590102 ft
Very nice and indeed the MPP was the better of the two. Thanks for sharing
2018-12-3
Mavic_Jay
Flight distance : 2113419 ft
very nice
2018-12-3
Bing Err
Sky Carrier Posted at 12-3 15:24
Yes, I assumed the MPP would be better in the wind but it was an OBVIOUS choice for more stable footage. And the 1st mission with the MA with the gimbal pointed down was actually really awful. I'm surprised it was that unstable. I'll have to do some comparative tests between the Spark, MA, MPP and possibly the Phantom 3 Standard if I can get mine repaired. Using Litchi to fly the same exact mission is a great way to do this since it takes all pilot errors out of the equation.
2018-12-3
Woe
Flight distance : 4129268 ft
This is a very good comparison.
2018-12-3
Bing Err
Woe Posted at 12-3 19:06
Thanks Woe. Litchi seems like a great tool to do comparative videos. I hope to do more in the future in various conditions (wind, lighting, camera settings, speed) Thanks for watching and commenting.
2018-12-3
Woe
Bing Err Posted at 12-3 19:20
No problem, love watching your movies.
I don't have litchi, but I'm starting to gain interest in it.
2018-12-3
Indeed. This is a good comparison
2018-12-3
Boffin
RE: Tried a Litchi Mission that was impossible to fly manually.
I was intrigued by Litchi after watching this and I asked the o/p why no disconnects on the orbits and he told me that it was a Litchi mission.
It was a 100% Litchi mission with the chase craft loaded with the same data but with an offset for separation.
So basically a totally autonomous flight, glad that it all worked, it's a smooth video Litchi Flight at Night
2018-12-4
davidmartingraf
Nicely done
2018-12-4
Keego63
Flight distance : 10082 ft
Wow what is that white stuff(I am in Australia), thanks for sharing.
2018-12-4
Bing Err
Keego63 Posted at 12-4 01:11
We got 8 inches of snow that night. Not a bad total for Minnesota. I do enjoy flying in the snow because it adds an interesting element to the videos.
2018-12-4
ShermanFlyer
Flight distance : 596896 ft
Very informative
2018-12-4
DeuceDriv3r
Flight distance : 5035761 ft
with both cameras set the same I am surprised by the difference in warmness / while balance between the two.  which of the two comes closest to the actual lighting at the time.. I assume that the water tower is lit with sodium lamps or some other high voltage industrial flood lights?
second, while I think the PP did better in flight, seems the video motion especially in the faster segments is noticeably smoother especially upper right vs bottom right.. the air even though its should be recording at a higher bitrate.. seems smoother than the PP.. possibly the litchi mission straining the processor of the PP more or perhaps the camera board on the air is just a better all over processing chip than on the PP
also upper right captured more snow blowing around than the PP.. but that could have been jut the environmentals at the time
I think the PP had better overall contrast and or dynamic range.. I can see more details in the shadow portions of the video than on the air
nice comparison..
makes me happy that I picked up a mavic pro for 1/3 the cost of a mavic 2 and a coupe hundred less than an air!!
2018-12-4
Flight distance : 11959747 ft
MPP In #3 looks the best flight, maybe wind a little strong for MavAir, but video in MPP is very cold or blue with lots of noise, MavAir is a much warmer looking video, you never mentioned settings, I would expect the bigger craft to do better in the wind, MavAir has a tendency to pitch lower in heavy winds to cope, we see this with obstacle sensors being dropped for stable flight.
Although I’m sure you were close, but if you were not then in a RTH into the wind the MavAir will seriously out preform the MPP, many Mavic Pro lost because of slow speed into wind on RTH .
Overall great video thanks for showing.
2018-12-4
RGMGFitness
Flight distance : 233757 ft
Hah!  If I had a big yellow ear of corn in my back-yard I would probably try to fly my drone around that thing to.   Cool shots!  Wonder if it might look just as good doing a Point of Interest (POI) shot from 'above' it (pointing downward), then speed-ramping the footage around it (in post editing).  If you get above the tower it might fix the interference issue as well.  Just a thought...thanks for sharing!  Good stuff...
2018-12-4
Bing Err
RGMGFitness Posted at 12-4 09:29
I will try that. Haven't used the POI in Litchi yet, but I will figure it out. I'll also compare it to active track with the DJI Go 4 app. Good Idea! Thanks
2018-12-4
Bing Err
hallmark007 Posted at 12-4 07:58
Good tip on the slow RTH with Mavic Pro. Thanks
2018-12-4
Bing Err
DeuceDriv3r Posted at 12-4 04:52
Yes, I'm very happy I held off of the M2P and got the MPP instead. I'm having a blast with it. Also, I agree there is probably some wind and snow factors that are not quite the same in each video. I could do the same shots on a calm day and maybe throw in the Spark to get a nice comparison in daylight. I still think the MPP outperformed in stability in the wind.
2018-12-4
Bing Err
Boffin Posted at 12-4 00:09
That's an EPIC video and one of the reasons I bought Litchi. Also, the reason I bought the app on Android and iOS. Once I get more comfortable with Litchi I want to put 3 drones in the air at once and do some formations. Dirty Bird was the inspiration for all this, but it'll take a while to get to his level.
2018-12-4
DJI Panda
Flight distance : 405039 ft
Interesting try. Thanks for sharing.
2018-12-4
jacksonnai
Malaysia
Great flight, nice video
2018-12-5
BHProductions
Flight distance : 43018593 ft
Very informative! Thanks! I may have to get in to using Litchi for some projects I have in mind.
2018-12-5
Atlas_Aus
I was wondering if it was rain or snow I have heard of Litchi but not checked it out, maybe a good idea Great footage BTW.
2018-12-7
Bluehook
Flight distance : 790814 ft
Bing Err Posted at 12-4 03:23
Yeah, but isn't the moisture bad for the drone?
2018-12-10
Bing Err
Bluehook Posted at 12-10 15:47
It gets VERY dry in Minnesota during the winter. So any small amount of moisture picked up during the flight would immediately evaporate when brought inside. I'm sure more moisture damage would be done long-term by just living in a more humid environment like the NW Coast or Southern sates like Florida or Louisiana. Third winter flying in the snow and no damage yet.
THANKS FOR WATCHING!
2018-12-10
AMZPOW
flying in the snow must be a amazing thing
2018-12-10
Bing Err
AMZPOW Posted at 12-10 22:05
Light snowfall looks really good on camera, and catches a lot of light and makes city lights glow. But heavy snow just reduces visibility too much to make it worth it. Here's a 360 pano I shot last winter with the Spark during light snowfall. Notice on the horizon it just fades to white since the visibility is reduced.
2018-12-10
AMZPOW
Bing Err Posted at 12-10 23:55
thanks for the useful information . I love the photo you show to me, wonderful!
2018-12-11
