Mavic pro platinum error
5089 12 2018-12-3
MartinsLV
Flight distance : 454557 ft
Latvia
So I have almost new mavic pro platinum and recent i'm having some problems with it. Sometimes in mid flight or when just turned on it disconnect live view and shows Aircraft Encoder Error(0x4800000) Also added picture with that error code. Is the problem easy fixable or is there some bigger issues? Drone flys great but only sometimes mid flight looses live view. And when there is error I can't move gimbal and shows no SD card but SD is in the drone. Hope to hear some advice.
2018-12-3
Alex B.
Flight distance : 21105262 ft
Ugh sorry for this mate but I think only DJI can fix hardware issue, Which I believe this is.
Sooner or later it will stop working completely and you will have to send it in for repair
Flysafely
Alex
2018-12-3
Hi Martins, our apologies for the inconvenience. May I know if your drone experience hard landing before? In this case, It is possible that there's an error with the camera coaxial cable (MIPI), or it is not connected properly. I would recommend that you restore the settings to factory defaults and refresh firmware using DJI Assinstant 2. You can download the software here: https://www.dji.com/mavic-pro-platinum/info#downloads and follow the video tutorial below for your reference. If the issue persist, I would suggest you to contact our support team to start up a case: (https://www.dji.com/support?site=brandsite&from=nav). We have a professional team who would do their best to find out the reason of the issue and then the corresponding resolution would be provided. Thanks for your support.
2018-12-3
MartinsLV
Latvia
DJI Paladin Posted at 12-3 03:55
https://www.youtube.com/watch?v=HZE-fP28htI[Image]
Drone has never had hard landings.
2018-12-4
MartinsLV Posted at 12-4 03:44
I understand. May I know if you already tried the troubleshooting guide on post #3 ? Is the issue is still the same? If yes, please contact our support team to start up a ticket. You can use the link on post #3 to contact our team. If you need further assistance with your case, please don't hesitate to contact us. Thanks for your support.
2018-12-4
MartinsLV
Latvia
DJI Paladin Posted at 12-4 03:53
So now the problem doesnt appears and I havnt done the steps you mentioned before. Now if the problem appears again I'll try the method but for now everything works just perfect. I'll let u know more later. Thanks for information.
2018-12-4
MartinsLV Posted at 12-4 23:09
You're welcome. Please keep me posted. Enjoy and always have a safe flight!
2018-12-5
djiuser_qSrjKOVaYlHB
how is your platinum doing?   I started flying a new one a few days ago.. having the same problem
2019-1-24
Jan Ive
Flight distance : 6480 ft
Hi, I have a platinum too, and have the same problem. Did you solve this?
2019-4-30
Jan Ive
Hi Have exactly the same problem. Tryed to refresh firmware but sometimes the screen is black when i start up.  Any solutions?
2019-5-2
djiuser_3lVOpXAp7J9S
Same error
2019-10-9
djiuser_FYoC1lP3ZENI
So I’m having this issue also. I tried the assistant download. Seems like since the original post was made and replied they might have changed the website. It doesn’t look anything like the video. HELP.....
2020-4-5
djiuser_4eCObHFzUCNC
Flight distance : 1099 ft
My Mavic Pro Platinum started to show up an error: "Aircraft Encoder Error(0x5000000)".
I can't find anything about this error. Did anyone have the problem? "Navigation system error" came as a bonus... O.M.G.!!!  Know what I can do to fix my bird? I'd appreciate any help?
2021-3-24
