Distortion on P4 pro camera
1022 4 2018-12-15
Peo
Flight distance : 25410804 ft
Why is there so much distortion of vertical lines both on the right and left short sides of photos, especially when you aim down the camera slightly
Can not Dji fix it with an update?
2018-12-15
In two years of flying a P4 pro, I haven't seen it or heard others complaining about it.
How about an example and an explanation of what you are doing with your images?
2018-12-15
Peo
Look at the arrows, the walls lean to different directions, it's lens distortion. Sure, you can fix it with Photoshop.
2018-12-15
DJI Natalia
Peo Posted at 12-15 05:07
Hi, we're sorry for the inconvenience caused. In most cases, customers are talking about volume deformation, instead of distortion. For details about volume deformation, visit http://www.dxo.com/us/photograph ... volume-deformation. Volume deformation (or anamorphosis) is caused by the way wide-angle lenses capture object volumes, particularly when the subjects appear along the edges of the image. This case will not occur when capturing two-dimension objects with their front sides facing the lens. But it happens when capturing three-dimension objects. Distortion is usually caused by lenses with short focal lengths and mostly affects straight lines. It is not possible to correct deformation and distortion at the same time. The Phantom 4 Pro lens corrects distortion automatically, so it does not process deformation. Optical distortion can be found in the Phantom 4 Pro lens. Compared with the Phantom 4, the Phantom 4 Pro’s sensor is large, which requires a large lens. However, the aircraft’s weight and lens’ size are limited. With certain distortion, lights can be reflected in the imaging area. This does not require a large lens while maintains an appropriate resolution. This method is widely applied in Japan and Germany. DJI works with a world-leading supplier to customize a compact lens with high resolution for the Phantom 4 Pro.
2018-12-15
That's just what happens when you look downwards with any very wideangle lens on any camera.
It's not optical distortion at all and it's nothing that DJI can fix with firmware or anything else.
As any real estate photographer knows ... If you want the verticals stay vertical, you have to ensure your camera is looking straight ahead and not up or down.
2018-12-15
