dronie1965
Flight distance : 24971795 ft
fans990dd5f1 Posted at 12-17 19:52
Just received mine, updated firmware and am very disappointed with the results. Impossible to pan without having all sorts of refocusing issues. Is there any way to lock the focus when not plugged into the phone? Is the AFS mode only available in pro mode? As I understand it I can plug the phone in, change to AFS and it will remain in that mode if unplugged, however, all pro settings are removed once I change the mode when unplugged. I bought it thinking the panning control would be much better than the gopro hyper smooth as it was glitching however since the gopro update it now pans much better then the osmo pocket. I like the osmo pocket as a device but for filming the footage is coming out terrible with focus continually pumping. It might be going back. I'm also wondering if there's any way to do timelapses in anything higher than 1080, although much bigger I'm finding the osmo mobile to be much more useful.
Tap on the screen of the display and hold you finger a few seconds on the yellow square, shoukd lock focus.
I already put forward the issue to dji( but i dont know if the are listening) regarding that you cannot change mode directly on the pocket when in pro mode. Indeed at the moment you have to connect your phone. Also the focus issues have been put forward, as many users( if not all ) facing focus issues(pumping), especially in afc. I also noticed kind of blur when panning. Hopefully it will be sorted with new firmware.
Dji? Firmware update befor Xmas?????? |
