[GPS]disconnect please reset and check connection, please urgent
2296 7 2016-8-23
franciscojavier
I was flying yesterday after updating to the latest firmware update and it lost GPS, switched to ATTI mode, so I landed it. Now, I can't fly my P4 due to an overall status message of "Cannot take off" with a detailed message of "[GPS]disconnect  please reset and check connection" when I try to start the motors. I am using the latest firmware and iOS app versions. I even tried downgrading the firmware and performing all calibrations (IMU, compass, gimbal) but still no luck. I've had no crashed or even close calls to crashes. I can't find any information about how to check/reset the GPS on the Phantom 4. Any help would be greatly appreciated! Thanks in advance!
2016-8-23
Aardvark
Flight distance : 384432 ft
Only things I could think of would be to refresh firmware and factory reset using DJI Assistant 2. Other than that you have no GPS signal showing on screen above which is why you cannot take off.
You've tried completely repowering everything after removing and re-installing battery ?
Nothing blocking GPS signal ?
2016-8-23
Moshe.mmm
Flight distance : 1320098 ft
Israel
Did you run dji go 2.8.4?
2016-8-23
franciscojavier
Thanks, yesterday sometimes worked and another times didi´t work (does not catch GPS, the same problem). I´m trying to update firmware using DJI Assistant 2.
2016-8-23
franciscojavier
I have update and reset with factory settings and the item continue without success. I have a urgent job and this is horrible.
2016-8-24
DJI-Paladin
Flight distance : 2408 ft
Hello franciscojavier, it is probably a hardware issue. Please send an email to support.eu@dji.com and send it in for diagnosis. Sorry for the inconvenience.
2016-8-24
fans8acd8861
Flight distance : 485781 ft
Hi did you get this fixed?  I have the same problem.
2017-8-12
Flyboy61
Hi. Has there been any resolution to this issue? I have the same issue on my M600.
2018-12-21
