dundee
Flight distance : 33550 ft
Hi all,
You can only see VPS and Arms LED light Toggle buttons when you TURN OFF the craft (Inspire1). See picture on post #18 from Rich above.
These options are already put in place on app version 1.2.0 (IOS). Not Android.
You can NOT deactivate VPS on the Inspire1 at the moment. (you can on the P3)
Imo, these functions will be activated in the next FW or app.
Not recommended, but unless you know what you are doing, tape the 2 sensors and make it blind.
If you do so, keep following things into consideration.
1) Landing gear will NOT lower automatically when approaching the ground (+/-80cm)
2) When the Inspire1 is on the ground, landing gear will raise when you flick the landing gear button up on the remote,
with a risk to damage or scratch the Camera/Gimble.
PS:
When VPS is disabled, then barometer readings should make the final decision to lower/raise the landing gear when you flick the button.
