Mavic Air ATTI
3164 12 2018-5-22
andy10
Flight distance : 4585692 ft
Slovenia
Does anybody know how to put MA into ATTI mode, as the controller has no switch for it?
2018-5-22
Suren
Flight distance : 13498560 ft
There is no switch for it and the drone does it automatically in the event of loss of gps, interference etc.
2018-5-22
sky6105
Flight distance : 345653 ft
maybe if you wrap it in tin foil you can block the GPS.
2018-5-22
S.D. Pilot
Flight distance : 10400463 ft
Fly underneath a tunnel and you'll instantly switch to atti-mode.
2018-5-22
DJI Wanda
Hi there Andy unfortunately there is no Manual method for you to change to ATTI Mode,
the unit will only change to that mode if it lost GPS Signal or a Weak signal.
2018-5-22
JJBspark
Flight distance : 12717890 ft
S.D. Pilot Posted at 2018-5-22 08:06
Well, if there is enough light it will switch to OPTI not ATTI.
2018-5-23
GDL
Flight distance : 2768694 ft
Fly in dark basement
2018-5-23
Adriano Araujo
Flight distance : 731565 ft
Did it with spark before.
If not too dark, It wil not ATTI cause VPS.
2018-5-23
andy10
Thank you all. Very nice picture of the tunnel  -  'SD Pilot'.
2018-5-24
PWingers2
Flight distance : 38261 ft
DJI Wanda Posted at 2018-5-22 08:07
Hi DJI Wanda,
Would it be possible to suggest that a software switch is added to the next revision of DJI GO 4, please?
I think it's an important part of learning to fly. Beginners and those in beginner mode may be easily caught out when they first encounter ATTI mode in the event of GPS problems. From a safety perspective, it would be much better for people to be able to choose when to try it out as part of their training.
Thanks for your contribution it is good to hear an authentic response from DJI staff.
Paul
2019-2-13
Flight distance : 11959747 ft
PWingers2 Posted at 2-13 09:56
Hi DJI Wanda,
I think it might be just the case that those practicing Atti mode found themselves crashing much more than those who lost gps and went to Atti mode, it was also a case with some Phantom 3’s that some people didn’t read the manual as many still don’t , switched to A mode crashed and decided to blame dji for not informing them correctly about Atti mode, I still read here every week people posing the question, what is Atti mode.
These consumer drones ie Mavic are a lot of users first drone so maybe best to make Atti mod Auto , and a good option to learn Atti mode is buy a cheap drone and learn with that, much less of a worry if cheap drone crashes than your €1500 M2 .
2019-2-13
AlphaFlightNW
Flight distance : 784265 ft
I'd fly through this tunnel. Given the proper safety measures, of course. Dont want to run into a car.
2019-2-14
AlphaFlightNW
hallmark007 Posted at 2-13 10:29
I agree. I got a tiny whoop and a tello which are both great aircraft to test atti mode as well as acro. Although, I wouldnt want a mavic air to go in acro mode, that would suck.
2019-2-14
