DJI goggles compatibility with QQ190 fpv
1637 20 2019-2-15
SioÜ_
Flight distance : 1850020 ft
Hi guys!!!
Does anyone know whether DJI goggles are compatible with QQ190 fpv drone?
2019-2-15
Woe
Flight distance : 4129268 ft
If it's 5.8 than yes. For the RE's
2019-2-15
SioÜ_
Woe Posted at 2-15 05:06
Sorry because I am newbiew on this WOE.
RE=?
thank you in advance
2019-2-15
Woe
SioÜ_ Posted at 2-15 05:13
RE=?
Which goggles do you have White or black.
If you have the white it will not work, they will work withe the black which is the
goggles RE's race edition using the 5.8 transmission.
2019-2-15
SioÜ_
Woe Posted at 2-15 06:30
Then they do
(black ones)
2019-2-15
SioÜ_
Thank you very much WOE
I will payback your imminent response
2019-2-15
Woe
SioÜ_ Posted at 2-15 06:53
No worries my friend. The first time connecting can be tricky.
good luck and let me know if I can help.
2019-2-15
Hello and good day SioÜ_. Thank you for reaching out and for the inquiry. I am sorry to say that we do not have any information if the DJI Goggles is compatible with the QQ190 fpv drone.  I hope you'll get the best answer here from our valued DJI Members and Customers regarding this inquiry. Just a friendly reminder that we do not recommend using 3rd party drones for the DJI Goggles. Actually, there is a possibility that the DJI Googles will be able work on the said drone . However, since it's not yet optimized and tested by DJI we cannot guaranteed the stability of the DJI Goggles if it will work all the time with no issues while using with the QQ190 fpv drone. Thank you.
2019-2-15
SioÜ_
DJI Stephen Posted at 2-15 08:31
You are most welcome!!!
Be my guest at my new video
Gratitude SioU
2019-2-15
SioÜ_
Woe Posted at 2-15 06:59
I will WoE
I tried to fix the problem with the video of Thessaloniki
2019-2-15
SioÜ_ Posted at 2-15 14:44
Gratitude SioU
It is always my pleasure SioÜ_. Have a safe and happy flying always.
2019-2-15
Woe
I will WoE
I just watched it and WOW.
2019-2-15
SioÜ_
Hey Woe!!!How are you my friend...
I have matched qq190 fpv with dji goggles but only in analogue mode?
The point is that some times the signal is weak and noise arises so creates uncertainty flying the drone.
Do you have any idea how can I surpass the problem.
Digital receiver or anything else?
2019-5-27
Woe
SioÜ_ Posted at 5-27 05:06
Try changing the the channels on the transmitter and the auto scan with the goggles. Or you may have to get a stronger one.
What type is it 25m or 200m?
2019-5-27
SioÜ_
Woe Posted at 5-27 16:11
I am totally noob WOe ...
And at the moment i am away from home
I will let you know on Thursday or Friday
I won ' t forget your assistance
2019-5-28
Woe
SioÜ_ Posted at 5-28 02:13
No problem my friend, I'm here to help.
2019-5-28
SioÜ_
Woe Posted at 5-28 04:18
Hey Woe finally i found some time to write back...
I was able to fly and everything ok, until i switched from band A to the racing band on my On Screen  Display, just for curiosity...
And from that time  I see nothing else than snow....
I do not know what to do.
I use analogue VTxMoreover the drone does not arm as i read since there is issue with VTx
2019-6-14
Woe
SioÜ_ Posted at 6-14 10:22
Try band  E Most fly with the band or F band
2019-6-14
SioÜ_
Woe Posted at 6-14 19:38
The problem is I do not know how to switch to band E.
Since I can't see the menu.
I see only snow in my goggles...
I installed TBS agent pnp pro but it does not have the tab that allows you to change OSD parameters
2019-6-14
Woe
SioÜ_ Posted at 6-14 20:48
Post a pic of the transmitter. maybe I can help by seeing it.
2019-6-15
SioÜ_
Woe Posted at 6-15 04:19
Ok I fixed that
-I just entered the goggles' setup menu
-Then entered the frequency tab
-Then switching to manual  search and began searching the frequencies
-And after a while they were synchronized.
-Now the other issue that arose is that my Rx control receiver  must be damaged.
-As a consequence the quad is not able to arm
-Typing  "status"  the CLI page at betaflight  reports
-RXLOSS
-The paradox is that The RX on the QQ190 looks to communicate with the Taranis XQ7 with the green -light
-However looking at Betaflight there is no response to my Taranis Control inputs.
2019-6-15
