M210-RTK for photogrammetry
7712 19 2018-6-5
gilrito
Portugal
Dear all
I would like to know if it is possible to use the RTK logs for doing the DG (direct georeferencing) of the images centers taken by the X4S camera?
Thanks. Gil
2018-6-5
Farnk666
Flight distance : 1711394 ft
No, the RTK data is only used for navigation - image exif data is from the standard GPS.
2018-6-7
gilrito
Portugal
Farnk666 Posted at 2018-6-7 06:22
Hi Farnk666
Thanks for the reply. But I wonder if it possible to use the RTK logs a posteriori for accurate georeferencing? It seems that we can use a survey grade GNSS in order to obtain the precise coordinates of the base station and introduce them with the DJI assistant to have an accurate georeferencing of the images centres. Is this correct?
2018-6-7
Grazer
Flight distance : 354357 ft
gilrito Posted at 2018-6-7 08:51
Hi Farnk666
As confirmed above by Farnk666, the RTK is for more precise navigation only. We use a PPK solution plug and play on M200 series for 50mm accurate geopositions. GeoCue Loki.
2018-6-7
Grazer
2018-6-7
gilrito
Portugal
Hi Grazer,
Thanks for the info. Does this solution also work with other cameras, such as X5S and Micasense?
What is the flight time that you achieve using the solution?
2018-6-8
M210 RTK will write the GPS coordinate of RTK in the image Exif data, it will display 1 when RTK is working. If it is 0, it records GPS module info. GTScreenshot_20180608_163122.png
2018-6-8
gilrito
Portugal
Thanks Dji for the info. So it can be used for accurate geotagging of the image centres if we introduce the precise coordinates of the base, taken by example with a  survey grade GNSS receiver?
2018-6-8
Farnk666
DJI Mindy Posted at 2018-6-8 00:34
M210 RTK will write the GPS coordinate of RTK in the image Exif data, it will display 1 when RTK is working. If it is 0, it records GPS module info.[view_image]
Hi Mindy - Thanks for that. Is this something new?
The original release of the DJI RTK solution didn't write the RTK data to the exif headers at all.
If it has been changed to do this, then that's a big difference in capability.
2018-6-8
Grazer
It is not survey accurate.
2018-6-9
Grazer
gilrito Posted at 2018-6-8 00:33
Hi Grazer,
This specific solution suits the X4s. As the X5s is a rolling shutter it is not suitable for photogrammetry.
The Micasense is not a supported payload either. Having said this, we have built custom solution for users using DSLR and Micasense on M600 Pro - PPK.
2018-6-9
gilrito Posted at 2018-6-8 00:39
I'm afraid not, RTK is used for precise flight and anti-magnetic interference, it is not recommended to be used for accurate geotagging.
2018-6-11
Farnk666 Posted at 2018-6-8 03:48
It will not for M600, but for M210, it will record the GPS coordinate of RTK all the time.
2018-6-11
Oscar Moreno
Chile
Hello everyone,
I have some questions about this Base RTK (Matrice 210), please help us:
Can you tell us in which band transmits ? and what is the differential correction transmitted ?
Thanks for your help,
Best regards,
2018-6-26
flymcg
So does the 210 RTK record positions relative to center pixel then?
A general point, DG (direct georeferencing) is not to be confused with RTK. DG is only achievable with a precise GNSS/IMU. RTK (in real survey terms, not DJI terms) is only half the solution, yes you can reduce your GCPs, but you still need to run high overlap. A system with DG capability can do 60/40 overlap.
2018-7-2
fans1f83baa2
Iran
Iwould like to know that can i use dji cristalsky for photogrammetry by matrice210 rtk?  Or i need just  ios ipa?d
2019-2-20
MedicFL1
Flight distance : 4358570 ft
fans1f83baa2 Posted at 2-20 22:32
Crystalsky uses the pilot app. iPad mini 4 can use the GS Pro 2.0 app.
If this is what you’re asking
2019-2-21
MedicFL1
2019-2-21
MedicFL1
2019-2-21
djiuser_60lJYy9sNuEp
None of the pictures I take with my M210 RTK has the RtkFlag = 1, so the RTK information is lost in the pictures... I'm using it with Zenmuse X5S and Z30, DJI Go 4 and RTK is fixed. Am I losing something?
Thanks!
2019-11-15
