warlex
Flight distance : 54793 ft
Ecuador
I have the same issue, my RC is faulty, then i try several things to make it work again (no luck).
If someone could make his RC work again following a list of procedures talked with DJI chat and emailed from support team:
1. Press power on 9 secs (RC hard reset), beeps but with no luck in my case
2. FN+Power+C1 at the same time when the RC is turned on (suppossedly to beep once), mine just beeps three times like when i press just the power on button >9secs, no luck in my case
3. Pause + Power On sequence (i read on other forums that this procedure helps when the RC is beeping all the time), no luck in my case, my RC just keeps blinking red all the time
4. Try to pair again with the aircraft, when i try the button sequence Pause+Fn+C1 and try to pair the RC just beep once and nothing else.
5. Try to connect the controller by OTG cable, with IOS (Ipad mini 2 and Iphone 6 plus) and with Android too (Galaxy S6 and Sony Xperia) no luck the devices aren´t recognizing at all the pluged RC.
So at this point i have a RC bricked (Red led blinking) and with a DJI Opened case waiting for sending back to them and pray if warranty apply.
Please if someone can share some light to this problem will be so much appreciated. Or share his own experience.
By the way my RC is brand new never used, because when i try to update (out of the box) the FW the Process stops suddenly and the screen just said reboot your RC (what i did) and now no SSID Wifi bradcast at all
Thanks |
