video stopped recording
861 9 2014-12-10
tomwolves585
Flight distance : 110577 ft
Hello all, today I  was doing a "way point flight",my tablet screen showed broke connection or something to that effect (I  knew  this would happen),but what I  don't understand  is that the  video stopped recording two minutes into the flight.My friend who Flys the same model when he loses connection his still records video.Any suggestion or help I  would appreciate  very much,thank you for your time.
2014-12-10
whyley27
check the settings in the dji app..
2014-12-10
kenargo
Under Vision App, Settings (on the main screen, before opening "Camera", there is a setting "When connection breaks".  Open the setting and make sure that "Stop Recording" isn't enabled; it sounds like it might be.
2014-12-10
tomwolves585
Nope! It isn't that kenargo, I   checked that to make sure.
2014-12-10
MatChen23
China
Hi, is that possible to borrow your friend's camera to connect with your aircraft? Your problem mihgt cause by the malfunction of the camera.
2014-12-11
tomwolves585
my video works it just stops when broke connection during way point flight. settings01.JPG
2014-12-11
Gerry1124
tomwolves585@gm Posted at 2014-12-11 20:40
If you want the video to stay on when your connection breaks, uncheck that.
2014-12-11
tomwolves585
Gerry1124 Posted at 2014-12-11 20:49
It is unchecked gerry,if it were highlighted  "green check" then it would be for the Phantom to stop video when broke connection . I  figured out the problem . I  flew this morning doing way points and all went well.Thanks everyone for all your input.The error was me,yep I  will be the first to admit it . apparently  I  shut the video off in the app in the beginning  of the flight,it was hard to see the tablet screen is my only excuse,and Adam good one!
2014-12-11
Gerry1124
tomwolves585@gm Posted at 2014-12-12 02:02
It is unchecked gerry,if it were highlighted  "green check" then it would be for the Phantom to sto ...
Glad to hear you got it, Happy Flying!
2014-12-11
tomwolves585
Gerry1124 Posted at 2014-12-12 02:14
Thank you Gerry, it was "happy flying" today.
2014-12-11
