Wearing, Device usb connect
447 1 2019-4-1
cutis
Flight distance : 1695351 ft
Does the receptacles get worn loose (male female junctions) from hundreds of attachments detachments?
Drone has usb receptacle
Rc has usb receptacle
Cellphone has usb receptacle
But what makes junction loose?
Male side of junction or female or both?
In asst2 cal, the provided flat ribbon usbC apparently jostles conduction thru the junctions said and asst2 doesnt like it.
So i resorted to samsung factory usbC cable which did not jostle conduction at junction connect (which side: craft or pc)
The cal mandates craft spatial orientation that jostles the cable . The more softer samsung cabling does not impart so much movement of junction connect.
Nevertheless, like cellphone receptacle, wearing from hundreds of connect disconnect evidences gradual junction fitup looseness.
Its the craft being moved to point at target cal screen which interrupts.
And this can fool users.
Dont know whether the samsung usbC cable eventually will also get loose too.
2019-4-1
Hello and good day cutis. Thank you for reaching out and for sharing this information and your insight with regards to this matter. I hope that you can get some information from our Co pilots who experience and  uses the Samsung usbC cable on there drones. Thank you for your support.
2019-4-1
