DJI Goggles mini USB port damaged.
1410 1 2019-4-29
True Detective
I fly the Phantom 4 Pro Obsidian and must connect the goggles to the controller via a cable from the goggles mini usb port to the controller. The port seems to be damaged because I have used two separate cables and the signal keeps cutting out. If I juggle the mini usb while it's in the port of the goggles the signal will cut in and out.  Is there a replacement port for these goggles?
2019-4-29
Hi, good day True Detective. We're sorry to know that you are having an issue with your DJI Googles. We highly recommend you to contact our support to open a ticket at https://www.dji.com/support. We have the professional team who will check your DJI googles to find out what would be the possible reason why that port been damaged. Please note that DJI will not perform data analysis for cases occurring after the expiry of the warranty period; otherwise, valid charges will apply. Thank you for your kind and understanding. Have a wonderful day.
2019-4-29
