Erratic input on right dial?
846 11 2019-4-6
LarryTru
Flight distance : 458944 ft
Hello Is anyone experiency some "bounce" with the aperature control on the right dial?
By that I mean that if I am not careful to return the dial to the center position carefully/slowly (e.g. I let it spring back on its own) then it fails to increment/decrement the aperature value.
From what I can tell, the software needs to have a "deadzone" around the center values on that dial to keep it from accidentally registering small values of the opposite polarity than is desired.
Larry
2019-4-6
SkyJax Aerial
Flight distance : 4127283 ft
Yep. Been through two smart controllers. They both do the exact same thing you described.
2019-4-21
marktottymy
Flight distance : 91860 ft
I assigned the aperture and EV to the up/down left/right on the joy button....works really well.
2019-4-21
SkyJax Aerial
marktottymy Posted at 4-21 20:49
Are you having the same problem? If you are, speak up to DJI about it.
That’s the only way things get fixed. If we accept these little issues DJI then they will keep overlooking them.
Dont accept compromises or work arounds with these products.
2019-4-22
DanielVieira
Flight distance : 4633533 ft
Portugal
Yes, i can confirm this also happens to me...
2019-4-28
SkyJax Aerial
Well, guys, I hate to tell you this, but  this is the email I got from DJI support about this issue:
"Thank you for your response.
I just received an update regarding your concern about the dial on the DJI Smart Controller. Our support team checked the video you sent and tested the RC dial of the Smart Remote on the facility like when you're demonstrating it in the video. They found that it was normal and it is very sensitive to touch.
They advised that please hold the wheel too long when pressing the CW or CCW. You need to press and quickly release it.
Should you have further questions, feel free to contact us.
Thank you for choosing DJI Products. "
So there it is guys. There is no problem with the shutter dial, and it's all because were not using it right.
I mean I dont know how this is possible since the Standard remote doesn't do this.
Not surprising considering DJI treats us like were stupid.
At any rate, I am fed up and done with DJIs lack of support and being treated like a moron.
2019-4-29
Nigelpugh7
Flight distance : 4917329 ft
That’s a good idea, we will try that too!
2019-4-29
Nigelpugh7
SkyJax Aerial Posted at 4-21 19:29
Yep we are also on our second smart controller.
The same happens on this one as it did not the first.
We think it’s software related as it actually lags, ie you make two button presses, but it takes seconds for the u it to perform the command,.
Often you think that you have not pressed the button so end up doing it yourself again, which means you sometimes make four movements up or down!
2019-4-29
SkyJax Aerial
Well according to DJI, they say that this is normal and just very sensitive so you have to suck it up and deal with it.
They’re not going to fix it.
2019-4-30
LarryTru
SkyJax Aerial Posted at 4-30 09:47
that's unfortunate.  It could be easily fixed in software.
2019-5-1
David Martin Graff
Yeah that's something interesting to look into?...
2019-5-1
SkyJax Aerial
I’m serious guys, you all need to call and request to speak to the service manager Ejay and tell them that this is not normal and you want it fixed. I’m the only one reporting this to DJI support so apparently they don’t see it as an issue. Please help and call to report this to them.
2019-5-2
