Gimbal Motors??????
BlueBaII
I had a technical question about the motors in the Gimbals when looking at the flex rebbion that comes from the motors there is 3 larg tabs witch i assume are for the power to the motor and then there is 5 smaller tabs witch i have no clue what they are for.  Any one have any ideas???
2019-5-7
Yes, there is also a rotary position encoder attached to the motor that tells it the rotational position, that's what the other contacts are for.
2019-5-7
Hi, thanks for the inquiry. We're hoping that you could get the best recommendation that you may need. For a friendly reminder, we're not recommending our customers to fix or modify the drone on their end as this process would void the validity of the warranty. We're encouraging our valued customers to reach our support in any case that the drone experiences incident to possibly use the warranty. If you wish to contact our support, please refer to the link Thank for or understanding.
www.dji.com/support
2019-5-8
BlueBaII
DJI Tony Posted at 5-8 09:51
www.dji.com/support
I did try Support they referred to engineering who then refused to answer the question stating the same response.  We're not recommending our customers to fix or modify the drone.  I never said i was fixing or modifying anything i was just curious as to what they where for.
2019-5-10
BlueBaII Posted at 5-10 16:59
Hi, thanks for the prompt reply. Since we're not recommending our customers to fix or modify the drone by their end, therefore, we couldn't provide further details in regards to the internal part regardless if this is curiosity purposes. Thank you for your understanding.
2019-5-12
I gave you the answer in post # 2
2019-5-12
