AlansDronePics
Flight distance : 823163 ft
Guernsey
Sadly, your logic does not hold water. Pun intended.
The water may be 'pure' up until the moment it is in contact with soluble substances, including metal itself. I know your objective is to dissolve and flush away corrosive salts, and that makes sense. However, water is not good at penetrating small cracks or gaps due to surface tension. You know surface tension, don't you? Where water forms droplets or a distinct border at the edge of the water. The salts left over from dunking love these crevices and will remain active , absorbing atmospheric moisture to continue its silent, destructive action. The worst areas are where you have wound cores and dissimilar metals. Loads of cracks to hide in.
If the electronics belong to something that is not going to fall out of the sky, like a camera or laptop, then fine, it is worth the risk. It is irresponsible to fly something that has a known defect.
Regarding the use of desiccants. Rice and silica gel, will absorb moisture to a degree, however, unless you seal the stuff in a bag, the infinite amount of moisture in the air will quickly saturate it. Don't waste your time with desiccants except for storage of dry equipment. Just rely on warm air passing over the damp equipment. That is how evaporation works. Why else would washing on a line dry?
