Firmware 1.3.20 - DJI Go 2.0.0 App Discussion Thread
30056 305 2015-8-3
jafarini
Flight distance : 15252589 ft
Georgia
Is video lag fixed in this firmware?
My Nexus 5 is getting very hot and I loose video almost on every flight. This issue is killing me.
I was planning to upgrade to the Samsung Note 4 but I see many people with Note 4 also complain.
Please leave comment if anybody has tried the new firmware on Nexus 5 or Note 4 and if video lag (crash) is fixed.
Thanks!
2015-8-5
soerheim.emil
Update complete. Got two flights and everything is working perfect.
Edit: On third run the streaming did lag....
2015-8-6
Mudcon
jimcloud74@yaho Posted at 2015-8-6 09:52
I am at a loss as to why you don't get video past 1.1.9. You should be getting at least close to a ...
it seems that everyone started having problems at 1.1.26/28 when they chopped 32 channels down to 8
2015-8-6
Nico
sp.thanos Posted at 2015-8-6 02:10
i sent my defective battery back to DJI for inspection..
Can you power on the aircraft with that  ...
I think it had something to do with overheating. After I left it for about ten minutes the battery was able to be charged again. Weird though since it was about 25 mins from the moment I stopped flying and started charging.
2015-8-6
david.p.mann
Flight distance : 18669501 ft
pulsar747n Posted at 2015-8-6 07:17
By cold, do you mean comfortable room temperature or do you mean putting it in the Refrigerator?
Always a good idea to do an IMU calibration after every firmware update with the P3 on a perfectly flat (use bubble level) non-metallic surface that contains no re-bar (don't use your driveway, sidewalk, ground floor of your house (if on a concrete slab), or parking lot).
YES - if you want to avoid seeing IMU warm-up messages on every first power-up, you need to chill the P3 prior to performing an IMU calibration.  I put mine in the fridge for 30 minutes - camera lens fogs up, but it doesn't impact IMU calibration.  Then, after IMU calibration is complete, with the P3 still sitting on the same level surface, do an Auto Gimbal Calibration to get level camera horizon.
Note: the Gimbal Calibration is not complete until the camera shifts left and right several times and then snaps to directly forward position and then slowly makes minor adjustments in camera tilt for next 60 seconds or so. WAIT until it's done before powering down P3.
2015-8-6
Kel-photography
I updated and tested 2 batteries. everythings seems great! I even used normal mode in my iphone 6+ and the video feed is stable, great jod, DJI!!
My devices:
P3P, iphone 6+, FW =latest, App = latest
2015-8-6
jimcloud74
Flight distance : 1298317 ft
jafarini Posted at 2015-8-6 15:52
My Nexus 5 is getting very hot and I loose video almost on eve ...
I ran 2 batteries almost back to back. I tested my 8.4 tab and my 10.1 tab. Zero lag. Zero heat. So, yes, it appears to be fixed for me anyways.
2015-8-6
rieckstudioaust
Hi Group -
I had an successful upgrade on the craft but not on the RC. I have an GL300A RC model and cannot get the RC to upgrade from my USB stick. Anyone else found a workaround or reason?. Craft and RC are paired , seems to be normal, however I havnt test flown yet because its midnight downunder. cheers!
2015-8-6
kelleyre
Flight distance : 90833 ft
I have the Inspire 1.
I came to the phantom forums to see if this was happening with the phanoms with the new update, and it looks like there might be a common problem  ( The App???)
I just got everything updated with the latest firmware and everything went well, I just did and Imu calibration, then I also calibrated the compass,I was just about the lift off when I noticed that the radio quality went from good to poor then I got a disconnect. I've been flying this inspire now for about four months and it's been awesome, absolutely no issues whatsoever until today. One very odd thing is that the indicator at the top of the app that indicates level of the radio signal, not the video signal indicator, but the radio signal indicator is showing full bars but I'm still getting getting good to poor messages and then all of a sudden it will disconnect and then reconnect.  I thought I would mention one more thing, after loading the updates on the inspire 1 and the RC controller I was in the app looking around and all of a sudden it crashed the iPad totally rebooted it. The ipad that I'm using is the latest air with 128 gigs  with the cellular radio in it.  It hasn't crashed since it rebooted.
At this point I  guess I'm going to have stopt flying until I can get some more information about what's happening, just a little unnerving.
I guess I'll try and call DJI or get on the chat and see if maybe they have any ideas.  Fingers and toes crossed
  Thanks for any ideas you guys may have
RK
2015-8-6
rieckstudioaust
rieckstudioaust Posted at 2015-8-7 00:04
Hi Group -
I had an successful upgrade on the craft but not on the RC. I have an GL300A RC model an ...
ok- It's been a long night but its all updated. The workaround for the RC model GL300A update is to load the update from the SD card (inside the gimbal). Remove any text files that generated from the P3 update and just leave the firmware file. Connect the cable from the gimbal to the RC. Power on the P3 first, wait 20 sec then power on the RC. Within 60 seconds the RC LED will go from green to Blue.  After the upgrade the RC will return to 'green' light status. Power off the P3 and then the RC.
Happy Days!!
2015-8-6
Phantom Help
Flight distance : 228255 ft
If anyone is having trouble installing the firmware, try following these instructions exactly:
http://www.phantompilots.com/threads/how-to-install-phantom-3-firmware-if-using-dji-go.50065
www.PhantomHelp.com
Find the latest must-haves, fixes, mods, how-tos, guides, and accessories for your Phantom.
Phantoms in stock and ready to ship worldwide! (see availability)
2015-8-6
toresoderlund
Can  not update the RC with Firmware 1.3.20
I have a Phantom 3 Professional with ipad AIR2 and DJI Go.
Updating the Aircraft with Firmware 1.3.20 without problems.
And also the batteries without problems.
But when I insert the SD card into the RC, start running it. Red light comes on. But it remains red at all times until it beeps and turns itself off after about 10 minutes.
It reads, in other words not from the SD card. Have no problem with the card reader. And SD card are the same as in aircraft.
The RC seems to work well with aircraft but I would anyway like to have the same firmware in both aircraft and RC.
DJI Go app says I have the firmware 1.3.20 on aircraft, but the RC must be updated. Very grateful for the advice. The model of the RC is 300A.
2015-8-6
thierryd
tcoleyrn Posted at 2015-8-6 07:01
I've updated my  FW on my P3P and my RC. Question: DO I LEAVE THE .bin FW FILE ON THE MICRO SD CARD  ...
have the same issue and to avoid this, I kept the file into the card
2015-8-6
heybutch1
Flight distance : 526946 ft
I'm still getting the 'no signal' issue. 3 mins into the flight yesterday the signal and video stream went dead. Still had control of the thing so just landed. Tried everything. New cables. New devices (iPad / iPhone). Deleted / unstaled apps. Turned on / off hardware decoding. Cleared the cache. Updated firmware. Fortunately it's still in the 14 days and the company I bought it from (not DJI) are going to do a swap. Should have new one here Saturday.
2015-8-6
fred
yegorius Posted at 2015-8-4 21:04
I can not update the firmware on Phantom 3 Pro (v1.3.20). At first time updating process was about 2 ...
mine does the exact same thing, same sounds, even that buzzing, grinding at the end.  What is wrong with them?  I also get no video.
Do me a favor please, look in misc/log on the sdcard, there is a log file that shows your updates.  see if your first one with the new firmware looks like mine.  Notice that after some of the items were updated the next try sees them as "not detected."
[00014480]========== remo-con disconnect. boot(15) ============
[00014519]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x88f02ae8].
[00014560]Packet upgrade start...
[00014607]Packet checking...
[00014646]Done.
[00014686]Version checking[1]...
[00014762][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014842][03 06][00] v2.2.6.8 -> v2.2.6.19 need upgrade.
[00014887][04 00][00] v1.38.0.0 -> v1.40.0.0 need upgrade.
[00014936][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015060][11 00][00] v1.6.0.0 -> v1.7.0.0 need upgrade.
[00015150][12 00][00] v1.8.0.0 -> v1.8.0.0
[00015250][12 01][00] v1.8.0.0 -> v1.8.0.0
[00015433][12 02][00] v1.8.0.0 -> v1.8.0.0
[00015530][12 03][00] v1.8.0.0 -> v1.8.0.0
[00028070][15 00][00] device not detected.
[00028166][17 00][00] v1.1.1.6 -> v1.1.1.7 need upgrade.
[00028306][17 01][00] v1.0.2.5 -> v1.0.2.7 need upgrade.
[00028377][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028420][01 00][00] v1.15.3056 -> v1.23.3419 need upgrade
[00028464][01 01][00] v1.15.3056 -> v1.23.3419 need upgrade
[00041009][08 00][00] device not detected.
[00041051]Done.
[00043094]Waiting for user confirm...
[00053136]Timeout, start upgrade automatically.
[00053228]Firmware upgrading[1]...
[00064805][01 00] Firmware upgrade start...
[00014238][01 00] Firmware upgrade finished successfully.
[00014280]Done.
[00014322]Packet [C:\P3X_FW_V01.03.0020.bin] resumed, card sn [0x88f02ae8].
[00014366]Packet vlink 01.03.0020 <-> 01.01.0009.
[00014440]Version checking[2]...
[00014524][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014604][03 06][00] v2.2.6.8 -> v2.2.6.19 need upgrade.
[00014657][04 00][00] v1.38.0.0 -> v1.40.0.0 need upgrade.
[00014719][09 00][00] v1.7.0.3 -> v1.7.0.3
[00014844][11 00][00] v1.6.0.0 -> v1.7.0.0 need upgrade.
[00014933][12 00][00] v1.8.0.0 -> v1.8.0.0
[00015033][12 01][00] v1.8.0.0 -> v1.8.0.0
[00015133][12 02][00] v1.8.0.0 -> v1.8.0.0
[00015233][12 03][00] v1.8.0.0 -> v1.8.0.0
[00027777][15 00][00] device not detected.
[00027874][17 00][00] v1.1.1.6 -> v1.1.1.7 need upgrade.
[00028015][17 01][00] v1.0.2.5 -> v1.0.2.7 need upgrade.
[00028080][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028125][01 00][05] v1.23.3419 -> v1.23.3419
[00028167][01 01][00] v1.15.3056 -> v1.23.3419 need upgrade
[00040709][08 00][00] device not detected.
[00040750]Done.
[00040794]Firmware upgrading[2]...
[00040937][01 01] Firmware upgrade start...
[00071186][01 01] Firmware upgrade finished successfully.
[00071253][17 00] Firmware upgrade start...
[00161781][17 00] Firmware upgrade finished successfully.
[00161837][17 01] Firmware upgrade start...
[00228320][17 01] Firmware upgrade finished successfully.
[00228369][11 00] Firmware upgrade start...
[00277595][11 00] Firmware upgrade finished successfully.
[00277810][03 06] Firmware upgrade start...
[00573141][03 06] Firmware upgrade finished successfully.
[00573208][04 00] Firmware upgrade start...
[00630756][04 00] Firmware upgrade finished successfully.
[00630796]Done.
[00630838]Version checking[3]...
[00630922][03 05][00] v34.2.0.9 -> v34.2.0.9
[00631002][03 06][05] v2.2.6.19 -> v2.2.6.19
[00631060][04 00][05] v1.40.0.0 -> v1.40.0.0
[00631116][09 00][00] v1.7.0.3 -> v1.7.0.3
[00631245][11 00][05] v1.7.0.0 -> v1.7.0.0
[00631345][12 00][00] v1.8.0.0 -> v1.8.0.0
[00631431][12 01][00] v1.8.0.0 -> v1.8.0.0
[00631515][12 02][00] v1.8.0.0 -> v1.8.0.0
[00631616][12 03][00] v1.8.0.0 -> v1.8.0.0
[00644159][15 00][00] device not detected.
[00644251][17 00][05] v1.1.1.7 -> v1.1.1.7
[00644391][17 01][05] v1.0.2.7 -> v1.0.2.7
[00644457][19 00][00] v1.0.8.96 -> v1.0.8.96
[00644499][01 00][05] v1.23.3419 -> v1.23.3419
[00644541][01 01][05] v1.23.3419 -> v1.23.3419
[00657084][08 00][00] device not detected.
[00657125]Packet upgrade failed at version checking.
2015-8-6
dansonamission
Flight distance : 469508 ft
pete.c44@gmail. Posted at 2015-8-6 08:10
Be sure to re-calibrate your RC sticks.
I've made sure the sticks are calibrated. Also did a cold IMU last night and few today, still the same issue.
Looking at the phantom the camera is pointing off to the left rather than straight forward so even manually flying it straight the footage doesn't look like its flying straight.
2015-8-6
toresoderlund
rieckstudioaust Posted at 2015-8-7 00:25
ok- It's been a long night but its all updated. The workaround for the RC model GL300A update is t ...
Did exact that you wrote. Got to try three different micro usb cables. And the third, it worked
2015-8-6
toresoderlund
toresoderlund@g Posted at 2015-8-7 00:59
I have a Phantom 3 Professional with ipad AIR2 and DJI  ...
Fixed. thanks to "rieckstudioaust"
2015-8-6
Inspector_Tim
Flight distance : 35899 ft
IPad mini 2 p3p
2015-8-6
Inspector_Tim
Inspector_Tim Posted at 2015-8-7 07:42
IPad mini 2 p3p
Meant to say, updated no problem. IPad didn't automatically update the RC via the Go app, used a USB stick.. Success
Took about 22 minutes on bird, less than two on the RC
2015-8-6
mgraphix
Adamation Posted at 2015-8-5 01:39
Since Updating my P3P to the latest firmware along with the remote the Android DJI App no longer mak ...
I also have this same problem with a phantom 3 but with and iPad Mini running IOS 8.4. The remote control will not connect to the iPad. We also tried a second iPad mini, installed the DJI Go 2.0 app and same thing, never connects so the app doesn't launch. Removed and reinstalled the app on the first iPad and no luck either.  Thoughts?
2015-8-6
kcit21620
Hi all,
My RC is model GL-300B
I'm using a Galaxy Tab S 8.4'' Android and the Pilot App.
The P3 updated fine but I don't know if the RC updated correctly it keeps telling me I need a Firmware Update in the Pilot App.  The Update for the RC fails when trying update it with the Pilot App.  I tried with a S5 with the Pilot App and it also fails.
When I try to boot the RC from a SD card nothing happens the light stays red and doesn't beep.
Will plugging the RC into the Gimbal with the new Firmware on the card work to update the RC ?
2015-8-6
Phantom Help
Yes. But, that would be equivalent to plugging a USB drive and/or memory card reader directly into your remote controller. The following instructions cover that direct connection method:
http://www.phantompilots.com/thr ... -using-dji-go.50065
www.PhantomHelp.com
2015-8-6
kcit21620
Phantom Help Posted at 2015-8-7 10:15
Y ...
I have tried plugging in a card reader and a flash drive directly into the RC ( model GL-300B ) but nothing happens !
The light stays Red and there are no sounds..
I guess I'll have to wait for the new Android App to come out and try to update the RC
2015-8-6
rayrokni
Flight distance : 8139875 ft
sploodge Posted at 2015-8-4 16:02
Hovering is steady too.. Baro readings seem accurate again..
hey,
my p3p used to be pretty steadi inside with vps, used to have 126 fw, now with the latest it does not hold steady, it does move and i have to keep correcting it. i think it because of the floor which is concrete, pleanty of light but there really is not much contrast from grey concrete, do u think that is it? i really dont fly indoors so o big deal but suppose if vps is not working that good then it could be an issue when im flying low outside.
thanks
2015-8-6
Phantom Help
rayrokni, VPS is not going to work well on surfaces that do not have a clear pattern.
www.PhantomHelp.com
2015-8-6
rayrokni
bastell Posted at 2015-8-4 18:56
Just make sure you remove the notepad file off the sd card after upgrading each battery.
you absolutely dont need to remove the txt file;
the operating system does not look for a txt file when it boots up, it looks for fw bin file and if it finds one newer, then it will install it. Once installed it creates a txt file if there is not one there already, if there is one there then it just adds an entry into the same txt file.
2015-8-6
rayrokni
i keep seeing posts about " the FW does not complete successfully, i waited 20 mins and all it was doing is four rapid beeps, so i shut it off and now it does nothing"
it is really simple, this fw is taking around 24-25 mins, and you are going to hear four rapid beeps, just leave the thing be for god sake, put the damn card in and go do something for 30 mins, heck go for an hour!!!!
patience guys, patience
2015-8-6
kriskhalil
Honduras
Hi all!
I have updated firmware in the past with no issues and used http://www.phantompilots.com/thr ... -using-dji-go.50065
I'm having some major issues with updating the firmware; the bird is not even beginning to update, and now i have lost ALL video feed.  The gimbal starts up normally then 'droops' after 10-15 seconds. I made a video but I am on an island (that I was hoping to shoot) and the upload speed is dismal here, so I can't post it.
2015-8-6
kriskhalil
Honduras
I flew 72 hours ago with no issues. Yesterday I tried to send my bird up and lost video signal after about 3 seconds. After looking online, I saw there was a new firmware upgrade, and thought this would be the best fix.
I've downloaded the new app, I DLed the new firmware, and when trying to update the phantom via SD card to gimbal...IT WON'T UPGRADE! I've upgraded my firmware each time, I am familiar with the process, and did everything properly. I've checked the ribbon cables and they seem to be fine.
The Gimbal LEDs do not flash red/green...and there's no beeping noise. I've let it run for 50 minutes just in case and it doesn't work. On top of that...the RC will not upgrade with a usb stick OR by connecting to the gimbal...
I've tried reformatting, trying 4-5 different SD cards, re-downloading the app, re downloading the firmware...Doing it on MAC and Windows..
I've even tried going back down to the previous firmware, the bird WILL NOT UPDATE!
PLEASE HELP! I'm on a trip on am island visiting friends and I can't fly my p3! I want to get this bird back in the air! DJI is being unresponsive!
I am using a macbook pro; iPad air 2 and have 1.3.2 and go app 2.0.  I'm not a n00b.
2015-8-6
kriskhalil
Honduras
I'm so sad and frustrated. Especially with DJI and their poor customer service.  I've wasted several international minutes today calling and getting to no one who could help w/ the P3. I'm on a trip trying to film a paradise island (can't wait to show you the 10 seconds of footage I do have! haha)
Anything will be much appreciated !
2015-8-6
rayrokni
Phantom Help Posted at 2015-8-7 10:33
yea im just gonna take it somewhere with somewhat of a good pattern and contrast and see!
thx
2015-8-6
rayrokni
kriskhalil@hotm Posted at 2015-8-7 11:57
I'm so sad and frustrated. Especially with DJI and their poor customer service.  I've wasted several ...
try reinstalling fw 126 if u have a pro or 128 if u have advanced
2015-8-6
bastell
Flight distance : 1526929 ft
rayrokni Posted at 2015-8-7 11:37
the operating system does not look for a txt file ...
Yuh you don't have to but makes it a much easier to read the results from the flashed battery
2015-8-6
rayrokni
bastell Posted at 2015-8-7 12:21
sure, i suppose 1 entry is easier than lets say 2 or 4!!
2015-8-6
krasnoperovrw
I do not work the remote control dji pilot, when you connect your smartphone or tablet to control panel , nothing happens !
Also with the remote control , I can control only the tilt of the camera on the copter .
The rest I can not control is available even motors can not turn !
What do I do , help ?
2015-8-6
krasnoperovrw
2015-8-6
jrobeznieks
Hi everybody!
Just tested new firmware 1.3.20
Hoping no issues this time...
The flight itself was perfect - rock solid while in hover,only one moment lost connection for couple seconds
when the bird was right above me just 70 m,never happened before...
Made a few flights spent two batteries -no issues flies perfect.
As soon as I checked the video was surprised to see the telemetry tags on the screen.
anyone knows what to f////k is that
http://www.phantompilots.com/thr ... nal-firmware.49893/
Thinking to use the new feture - downgrade to 1.2.6 and probably reinstall ???
2015-8-6
kriskhalil
Honduras
rayrokni Posted at 2015-8-7 12:09
Thanks for the help - I have pro. I've tried to update using 126 and the unit just no longer finds the firmware bin file and does not try to update...
The LED status light doesn't even flash.. I'm worried.
Weird thing is that I can fire up the drone just fine even though it tells me that I have to update the
firmware, RC, and camera.
The RC will not update either!
2015-8-6
rayrokni
kriskhalil@hotm Posted at 2015-8-7 13:25
Thanks for the help - I have pro. I've tried to update using 126 and the unit just no longer finds ...
go to the settings  and see what fw versions are installed please
2015-8-6
