Mavic 2 propellers replacing - how often?
3191 10 2019-6-2
windpixels
Flight distance : 299216 ft
Romania
How often should we replace the propellers of the mavic 2? Can’t find anything on this topic in the user manual or on this forum.
2019-6-2
Mhinc
Flight distance : 151467 ft
Typically, if they are damaged.  If there is no damage or wear they should be fine
2019-6-2
windpixels
Romania
Mhinc Posted at 6-2 05:58
Ok, good to know. Thanks!
2019-6-2
Mhinc
windpixels Posted at 6-2 07:11
Sure thing   Happy flying!
2019-6-2
*DM*
Flight distance : 507087 ft
If you regularly fly in very cold temperatures it may be a good idea to build in some kind of regular prop replacement schedule.
Plastics/polymers get brittle once they cool. Their structure changes at molecular level. - This process can take place in temperatures well above freezing depending on the compounds used in the polymer.
A prop that is superficially looking ok could have hair line fractures. Add even lower temperatures at altitude and speed and this could lead to catastrophic failure.
Luckily, this is a fatalistic theory and whilst not entirely outside the realm of the possible I have not heard of a drone dropping out of the sky specifically because of the above
Still, replace a visually damaged propeller immediately.
Just sayin' .
2019-6-2
Hello and good day windpixels. Thank you for reaching out and for the inquiry. Please try to inspect the propellers regularly and each and every flight. If the propeller is scratched, bent, or damaged please replace them immediately. Should you need further assistance, please don't hesitate to contact us. Thanks for your continued support.
2019-6-2
nilsonleow
Flight distance : 136680 ft
Ukraine
+1
Inspect the propellers each fly and all will be good!
2019-6-2
windpixels
Romania
DJI Stephen Posted at 6-2 08:51
thanks! Will do!
2019-6-2
Ahmed Hussain
Flight distance : 1339761 ft
Kuwait
While hovering, if the drone is abnormal then check the props and replace.
2019-6-3
Ahmed Hussain
Kuwait
An other way to check your props
2019-6-3
You are very much welcome windpixels. Have a safe and happy flying always.
2019-6-3
