USB Bottom Connection - Work with Phone?
1354 6 2019-7-24
John Walker
Can I connect the base USB connection to my phone, as against the side connection?
2019-7-24
Aardvark
Flight distance : 384432 ft
EDIT scrub that, I've just realised I'm in the Osmo section....
2019-7-24
tripleburst
Yes you can. I've even updated my firmware that way.
2019-7-24
John Walker
tripleburst Posted at 7-24 06:42
2019-7-24
Hi, thanks for the inquiry. We would recommend connecting your phone via the Smartphone adapter or wireless module as using the bottom port is not optimized to connect the phone via cable. Thank you for understanding.
2019-7-24
Curt1591
Before the wireless finally made it to market, I always used the technique you describe. I had full control and never had any problems.
2019-7-24
Ray-CubeAce
Weirdly then, my phone works better connected to the bottom USB port than the side port.  Less lag and a more stable connection. If you are using the Pocket with the extension rod how else can you connect the phone other than via wireless? It doesn't make sense unless the whole exercise is just to buy more DJI peripherals. Not impressed for something considered pocketable.
2019-7-25
