My Air Unit is restricted to 25Mw and only 4 channels, In US
1656 3 2019-8-11
WrathPak
Flight distance : 78366 ft
I do not use a VPN.
I am in the US
I have done the activation and update to the goggles, air unit, and radio controller.
I only have access to 3 channels and the public channel, and cannot switch from 25Mw.
Help!
I have seen many people have this issue on other forums, no solution has been found.
2019-8-11
Hi, we do apologize for the inconvenience. May we know what mobile device are you using? I would recommend re-calibrating the IMU and compass then fly the drone in enough signal to see if that would work. You may try to re-install the app to see if there will be changes. Please save important files such as photos or videos and sync the flight records prior to deleting the application. For additional information, the aircraft and the application should be updated. Kindly keep us posted on the latest progress. Thank you for your support.
2019-8-11
Mafia16
Flight distance : 26490948 ft
Dominican Republic
make a .TXT file with name naco and a later 1 inside put it in the root of the air unit and it will unlock all the channels
2019-8-30
Mafia16 Posted at 8-30 03:46
I wish we could do that on the Mavic 2 pro too
2019-8-30
