Ronin-S Release Notes (09/26/2019)
123Next >
25732 88 2019-9-26
DJI Support
Flight distance : 2408 ft
Overview:
  • Date: 2019.09.26
  • Firmware: V2.0.0.90
  • Ronin App iOS: v1.2.4
  • Ronin App Android: v1.2.4
  • DJI Pro Assistant for Ronin (PC): v2.0.2
  • DJI Pro Assistant for Ronin (Mac): v2.0.2
  • User Manual: v1.2
What’s New?
  • Added ActiveTrack 3.0 (requires Ronin app v1.2.4 or later).
  • Added Force Mobile (requires Ronin app v1.2.4 or later).
  • Added quick switch to 3D Roll 360 mode. Press M button three times to enter, and press three times again to exit.
  • Added Auto 3D Roll 360. When the gimbal is in 3D Roll 360 mode, push the joystick left or right twice to enable Auto 3D Roll 360. The gimbal rotates continuously without needing to hold the joystick. Press the trigger twice to stop Auto 3D Roll 360.
  • Added video recording, autofocus, and focus pull support for Sony A7R4 cameras with supported E-mount lenses using a Multi-Camera Control Cable (MCC-C). To use autofocus on the A7R4, press halfway down on the camera control button of the gimbal.
  • Added photo capture, video recording, zoom, and focus pull support for Sony A7R4 cameras using a Multi-Camera Control Cable (Multi USB). To use autofocus on the A7R4, press halfway down on the camera control button of the gimbal.
  • Optimized 3D Roll 360.
  • Added Track mode settings for Command Unit.
  • Optimized follow experience in Flashlight mode.
  • Optimized the Profile LED display by changing the pulsing frequency when gimbal in sleep mode, and the LED will become red to indicate low battery warning when battery level is less than 20%.
  • Sleep mode can be enabled by pressing once or twice of the gimbal power button.
  • Optimized zoom adjustment when using Sony cameras’ multi-port with Power Zoom lens, The zoom speed can be set from 1 to 100 (requires DJI Ronin v1.2.4 app or later).
  • Fixed other minor bugs.
Notes:
  • Make sure that the DJI Ronin App is the latest version when updating the firmware.
  • Make sure Ronin-S is powered off and update the firmware through the DJI Pro Assistant for Ronin by connecting the USB-C port on Ronin-S to your computer. Do not disconnect the gimbal from the computer while updating.
  • After the update is complete, unplug the USB-C cable from Ronin-S and proceed to power on the gimbal.
  • If Ronin-S has a camera attached and is turned on while updating the firmware, make sure to protect the camera and lens as the motors will shut off during the update.
  • If the firmware update fails, restart the Ronin-S and retry.
2019-9-26
Thanks for the info!
2019-9-26
FlyRi
Flight distance : 708842 ft
And when Ronin app 1.2.4 will be available for download from apple store ?
2019-9-26
AntDX316
Flight distance : 3394731 ft
What mount do I use to attach the phone to the camera?
2019-9-26
DmytroK
AntDX316 Posted at 9-26 04:49
You can use a genuine phone holder https://store.dji.com/product/ronin-s-sc-phone-holder
Or any other phone holders from Ali/eBay
2019-9-26
KlooGee
Flight distance : 16783757 ft
This is awesome, but why is v1.2.4 of the iOS app not available yet?
2019-9-26
Volg.in
Flight distance : 8143 ft
KlooGee Posted at 9-26 05:12
This is awesome, but why is v1.2.4 of the app not available yet?
Same question
2019-9-26
Volg.in
Same question
2019-9-26
BrunoSlam
Can we now control the Sony A73's shutter, iso and aperture from the gimbal ?
2019-9-26
emkay
Flight distance : 358412 ft
Same question here. This would be really great for a shoot on the weekend. Fingers crossed this will be up shortly.
2019-9-26
Nikita Vladimir
Hello, I want to update my RoninS, I do everything according to the instructions, it is fully charged, I downloaded the DJI + Pro + Assistant + For + Ronin + 2.0.2 program, I turn it on to the computer, but the program does not go further to select the firmware. As in the photo I attached it. What is the problem ? the program does not find my RONIN S .... ((((
2019-9-26
emkay
Nikita Vladimir Posted at 9-26 05:39
If this is on a MacBook, I had to:
- use the Apple USB C power cable to connect the two
- use one of the ports on the right side of the laptop
2019-9-26
Nikita Vladimir
emkay Posted at 9-26 05:55
I have a regular windows 10 PC
2019-9-26
wingwing
This is awesome. Honestly I didn't have high hopes as the ronin-s as a gimbal already fulfilled my basic needs. I really didn't crave for any additional features new generation products have.........but good to have though!
2019-9-26
DmytroK
Nikita Vladimir Posted at 9-26 05:58
I have no problems updating the firmware on PC Win 10 64
Everything works fine.
Now I need a phone holder ))
2019-9-26
Nikita Vladimir
DmytroK Posted at 9-26 06:15
here it’s good for you, but this time it doesn’t work out for me ((
2019-9-26
Jason James
Flight distance : 827487 ft
I just updated my Ronin S using Mac and a Samsung Note 9 and and it worked fine. Here are a few notes that others may find useful:
- The DJI Pro Assistant app wouldn't recognize my Ronin with the first usb C cable I tried. Swapped the cable and all good.
- I couldn't update the Ronin app on my phone through the app itself due to a security warning. Did it through the Google Play store and all good.
- The video above says device should be powered off during firmware update, so that is what I did. HOWEVER, the DJI Pro Assistant app says to have the device powered on... see attached screenshot What is best practice?
Thanks DJI for keeping our Ronin S up-to-date with new bells and whistles!!!
2019-9-26
Nikita Vladimir
Jason James Posted at 9-26 06:44
my battery is 99% charged, but RoninS starts charging the battery, whether it is on or off, everything is the same
RoninS, but does not connect to the program ((
2019-9-26
Alejandro Ramos Morales
Hello! What is the best way to connect my camera to the gimbal? I'm very interested in the active track and pull focus features. Gear: ronin s, a7iii, batis 25 f2 & zeiss 55 f1.8
Thanks!
2019-9-26
Flyin Ryan 420
Flight distance : 2334925 ft
Same question for me.
2019-9-26
MrBernd
Flight distance : 297694 ft
Hello, why don´t you publish the supported Mobile Phone List here?
2019-9-26
MrBernd
Your Instruction how to update the firmware is confusing. Here you write: Make sure Ronin-S is powered off. When i started DJI Pro Assistant for Ronin, the App says i should Power on my Ronin S.
2019-9-26
IJD One above all
Flight distance : 137388 ft
Best update in a long time , DJI we are friends again
2019-9-26
amorrison
Flight distance : 325230 ft
After the update I had some odd jerkiness in the tilt using slight motions of the joystick.
I restored to factory settings and did an auto-tune and all is fine now. Very smooth.
2019-9-26
IJD One above all
IJD One above all Posted at 9-26 09:47
In Denmark we can update the ronin s with ~assistant . But it is not been updated yet through App Store for iPhones maybe tomorrow ,I hope we are stuck on 1.2.2 ( 126 )  . Looking forward to playing with this update
2019-9-26
IJD One above all
FlyRi Posted at 9-26 04:20
We also standing by in Denmark waiting . Come on Apple Store haha very nice update
2019-9-26
RJohn
Why no Ronin app 1.2.4 for iPhone? When will it be available?
2019-9-26
MrBernd
Supported Phones - Force Mobile
https://dl.djicdn.com/downloads/Ronin_SC/20190926/Force_Mobile_Supported_Mobile_Phone_List_en.pdf
Supported Phones - Active Track 3.0
https://dl.djicdn.com/downloads/Ronin_SC/Ronin_SC_ActiveTrack_3.0_Supported_Mobile_Phone_List_en_.pdf
2019-9-26
MrBernd
I just tested the Following Mode. Doesn´t work very well on Android. Drops some waypoints?!
2019-9-26
ronin_warrior
I love DJI! Thanks for the active tracking update.
2019-9-26
Mr.BobbyD
Update went swimmingly. I have tested Force Mobile to be working & Active Track too. I am having issues with the new 360 roll features. Pressing the Mode Button 3 times puts the gimbal into 360 roll position, but when I press the joystick left (or right) twice to initiate the new Auto 360 roll, the camera gets about 30 degrees through the rotation before it freezes up, jitters like crazy for about a second, then returns to centered position & restarts the auto 360 roll function. The issue repeats itself continuously until I press the Mode Button to change modes. This same issue occurs if I manually attempt to do a 360 roll using the joystick.
I've done a gimbal balance test and calibration and neither returned any errors. I used the app to switch to 360 roll mode & the issue still occurs. When I use the 3-toggle Mode Button press to switch to 360 Roll, I can confirm that the app sees the switch and sets the 360 Roll flag to "On." Lastly, Ive reattached the gimbal to my Windows 10 laptop, & done a "refresh" on the new firmware update and it went through (again) with no issues.
Is anyone else experiencing this issue or have you had it in the past prior to the update? It may be a setting I need to fiddle with, if anyone has any suggestions.
Thanks in advance,
BD
2019-9-26
M2Wair
Flight distance : 1192231 ft
Slap my thigh with a wet kipper and call me Mildred. Delighted is an understatement. We'll done DJI top job.
2019-9-26
Flyin Ryan 420
Woooo! Just got iOS update. Active track is a MAJOR MAJOR GO!
2019-9-26
Mr.BobbyD
Mr.BobbyD Posted at 9-26 11:47
I've had some success now with the auto 360 roll. It may have been an issue with the motor stiffness setting for Roll. I ran an auto tune and it started working.
2019-9-26
FebriKrist
It's same for nikon camera.. I can't start / stop video using infrared cable.. I am using nikon D 7100
2019-9-27
Nikita Vladimir
I love more and more DJI, unexpectedly, that my roninS is now update and get features, my camera weighs a little over 2 kg. I think I bought the best gimbal !!!!
2019-9-27
Nikita Vladimir
press M, quickly, and not as you usually switch 1-2-3 modes.
2019-9-27
RJohn
Got the Ronin app 1.2.4 for iPhone and everything works great.
2019-9-27
djiuser_3SpC8H1Qajsk
After updating my Roll/Pan motor VIBRATES LIKE CRAZY WHENEVER I PLUG MY FOCUS MOTOR IN and only when the focus motor is plugged in. I can also hear my motors making “harddrive” like noises constantly. This doesn’t happen with any other firmware versions, problem is when I downgrade my tilt axis has slow issues returning to straight after tilting down. What’s up?!
2019-9-27
thejamesnoble
Only issue I ever had was that my gimbal was slightly tilted up too much and wasn’t completely in flashlight mode once I leveled out it worked fine
2019-9-27
123Next >
