DJI-Delphine
![](https://forum44.djicdn.com/data/attachment/common/65/common_11_usergroup_icon.png) lvl.2
Hi everyone, we just want to let you know that we have recently released a new set of accessories for our Phantom 3 series.
Please see below for details of the accessories and which versions of the Phantom 3 they are compatible with.
Phantom 3 Battery Charging Hub
A simple way to automatically charge up to four Phantom 3 Intelligent Flight Batteries together. With clear LED indicators, this compact, easy-to-carry Charging Hub is perfect to bring with you when going on a trip.
Phantom 3 Propeller Guard
Includes 4 prop guards customized for the Phantom 3 series. Designed to protect your propellers during collisions, they help you fly with confidence, whether you are a beginner or an expert quadcopter pilot.
ND Filter
Phantom 3 - ND4 Filter (Pro/Adv)
Phantom 3 - ND8 Filter (Pro/Adv)
Phantom 3 - ND16 Filter (Pro/Adv)
It helps you to reduce the amount of light coming into the sensor.
It gives you the freedom to create your own work by allowing you to have more control of the camera’s aperture, exposure time and sensor sensitivity settings.
Phantom 3 HDMI Output Module (Pro/Adv)
The HDMI Output Module for the Phantom 3 (Pro/Adv) can export 720P real-time images via an HDMI port.
It can be used in broadcasting or video monitoring.
It supports a double-screen display, and exports real-time images via the HDMI and USB ports.
Phantom 3 - UV Filter (Pro/Adv)
The UV filter helps to protect the camera lens of your Phantom 3 (Pro/Adv), reduce the level of ultraviolet light.
Remote Controller Monitor Hood
For Smartphones,Pro/Adv
For Tablets,Pro/Adv
The Monitor Hood shields your smartphones/Tablets from direct sunlight to give you a perfectly clear view of your display.
Size for Smartphones:165mm*87mm*85mm
Size for Tablets:205mm*145mm*128mm
Remote Controller Strap
Its ergonomic design ease the pressure to the cervical vertebra.
Learn more: http://store.dji.com/phantom-accessories/for-phantom-3
