automatic battery discharge time?
1440 7 2019-11-21
djiguy001
hi!
first, finally found the voltage of batteries, which is good! didn't realize you had to click on the battery icon to display that.
So. This *may* be here, I don't know, couldn't seem to find it.
Is there an 'automatic' discharge of the batteries, similiar to the phantom series, if the battery hasn't been used? If so, where? Obviously I want to make sure before I go flying, that the batteries are fully charged - and if they've been sitting for a while - want to make sure everything is fine.
If there *isn't* an automatic discharge - should I 'drain' the batteries a bit myself if they are going to be in storage for a while? (Here, it is starting to get windy/cold/etc - so not sure how often I will be able to fly it).
Thanks!
2019-11-21
No auto discharge so you will have all info needed below.
2019-11-21
Hi. Thank you for reaching out to DJI Forum. For the automatic battery discharge, this feature is not available for the DJI Mavic Mini Intelligent Flight Battery. Please refer to the image provided by hallmark007 at post #2 for mote details. Thank you for you valued support.
2019-11-21
djiguy001
hallmark007 Posted at 11-21 08:37
kk, thx, good to know! btw - what happens if you "dont" automatically discharge the battery, does it become a 'bad' battery?
2019-11-21
djiguy001 Posted at 11-21 10:05
I’m not certain, I thought dji might have put up some more information perhaps to much to hope for, I’ll try find out and get back to you.
2019-11-21
Just found this, little more information, so really need to discharge batteries to 40/60 when not in use, also I would recommend charging every 6 weeks .
They should be easily reduced just use them for charging .
2019-11-21
Funn 1
Flight distance : 168999 ft
hallmark007 Posted at 11-21 10:15
WOW only 200 Cycles.....
2019-11-21
Bright Spark
Flight distance : 22129 ft
That's around 80 hrs air time. 40p/ hr?
2019-11-21
