Hi, thank you for reaching out and we do apologize for the inconvenience. The statement of Matthew on post #2 is correct, you need to make sure the stability of your connection when clicking the record button or shutter button for you to make sure that it will save on the SD card. However, if you are fully sure that you record or capture a footage, you can try to back-up all your files on your SD card and try to reformat it to see if the problem persists. Hope this helps. Thank you for support and welcome to the Forum! |
