Gimbal jerk up or down!?
3292 26 2019-11-30
Guorium
Flight distance : 513061 ft
Quite a bit of wind from behind the drone and I think I let the stick go because I wanted to brake right before the tree (I was under that). Then I saw this gimbal kicking up. Could this be a normal thing when sharp change in attitude occurs? I have seen this happening many times. Mostly they coincide with braking either in horizontal direction or vertical direction. Just one case it jerked downward while holding stready full speed forward in P mode.(wind from front-left) Please help!
I uploaded the flight log for the flight shown in this youtube video. The gimbal was at -90 and at 12m37s the braking caused a large tilt to the back (assuming the blue is craft attitude). https://www.phantomhelp.com/LogViewer/DCLUA5TF8OEK9VD6UK2Y/#
For the flight I did yesterday where the gimbal kicked down. At 1:30 and 1:50 the video kicked down. The 1:50 one was more obvious so the second video is showing just that. They both coincided with me returning throttle stick to neutral. The 1:30 event did not show change in attitude but the 1:50 event did (nose down). Maybe vertical braking tilted the body down somehow? I don't think it should though!
https://www.phantomhelp.com/LogViewer/OQHYLJPKJ2BOK9AB5YY2/#
2019-11-30
InspektorGadjet
Flight distance : 439915 ft
Post logs in case someone can see something. Not sure this is normal, I haven´t experienced it myself.
Let see if support can add some info.
2019-11-30
Guorium
InspektorGadjet Posted at 11-30 07:11
Ok i will find out how to export log first
2019-11-30
InspektorGadjet
Guorium Posted at 11-30 11:08
Logs are stored within the APP, you can access them using iTunes or also with the DJI Assistant 2 software.
Here some links that may be of use for you:
https://www.phantomhelp.com/tips ... logs-from-itunes.29
https://www.phantomhelp.com/LogViewer/Upload/
2019-11-30
AntDX316
Flight distance : 3394731 ft
This is what happens when they try to keep things under the 249g limit and increase profit margins.  You compromise having better PCB chips and components.  It could work some or most of the time but seeing a couple fly away reports is Not comforting.  Plus, one incident can make a couple Inspires 2 free.  It would just be nice if the reports could hit the internet for us to know about otherwise we would think nothing bad has ever happened.
2019-11-30
InspektorGadjet
AntDX316 Posted at 11-30 11:32
PCB and normal components would´t make the price to change that much, I think is mainly FW based.
Maybe the motors, compass and gps modules yes, they will have a huge impact in price and quality.
Let´s hope is all software based and they will eventually polish the behavior.
2019-11-30
AntDX316
InspektorGadjet Posted at 11-30 11:56
Yeah, perhaps the gimbal motors are smaller than they should be.
2019-11-30
InspektorGadjet
AntDX316 Posted at 11-30 15:57
I hope not!
2019-11-30
AntDX316
When things are built beefier, you can get away with certain defects.  Intel used to cherry-pick the processors that can perform the best and made them into extreme editions.  The ones that failed tests had cores not mad so instead of an 8-core CPU, it was made as a 4-core CPU.  That's just a binning guess.
Gimbal issues and flyaways at launch would make me stay away but of course, a lot of people wouldn't and there will be those who don't have any idea about any of these things, they will fly and crash.  It has happened, currently happening, and will happen in the future.  The only way is to get a different design that is proven to work with things ironed out or gamble it out.  I've skipped all the DJI drones prior to the Spark 2.  Besides the Inspire 1, everything is Ocusync 2.0 w/ the latest firmware.
Some companies cost cut their future products for many reasons such as tariffs.  It hurts at the consumer-level when people get improperly robust products.
2019-11-30
Matthew Dobrski
Flight distance : 1831050 ft
Mavic's (Mini) gimbal is not the strongest one for sure and it will not handle sudden braking well. This is the scenario when you release throttle stick from full to 0. The mass of camera is pushing hard forward against gimbal bearings while the drone is abruptly tilting up probably 45 deg. Not easy task for a gimbal of this size and grade. Identical - I assume - gimbal on DJI Osmo Pocket doesn't like sudden moves as well. Not much to worry about, I think, just try to avoid jerky manoeuvrings ...
2019-11-30
Guorium
Matthew Dobrski Posted at 11-30 18:41
45deg? But S mode max attitude angle is 30deg.
2019-11-30
Guorium
InspektorGadjet Posted at 11-30 11:18
Thanks man you are great! I updated the post with uploaded logs and the time of the events.
2019-11-30
Gu5s
Flight distance : 284728 ft
Czechia
I can confirm this happening occasionally as well - usually a little while after hitting a full stop of the bordering angles after releasing the gimbal wheel it jumps just like in the video...
It does not seem like a HW problem of the gimbal itself - more like a "release the gimbal control - returns to back to the neutral positon with a spring quickly and it overshoots briefly the neutral positon...
That's what i thought - it is annoying nevertheless.
2019-12-1
Guorium
Gu5s Posted at 12-1 00:04
I did not even touch the gimbal dial when that happened.
2019-12-1
Gu5s
Czechia
I will do some testing focused on this today - Will report back in couple of hours
2019-12-1
Matthew Dobrski
Guorium Posted at 11-30 19:13
No, you don't understand. I'm not sure what you mean by " attitude angle" ...  Whatever, just observe how the drone is reacting to abrupt throttle stick release, which you've applied. She will try to brake and stop immediately, which will require a rapid change of forward thrust to just the opposite. I'm not sure if that's exactly 45 deg swing, just guessing. Simultaneously the gimbal is trying to maintain stable camera position, but excessive forces involved are making it difficult. That's why you see occasional jump, I believe.
2019-12-1
Guorium
Matthew Dobrski Posted at 12-1 01:34
No, you don't understand. I'm not sure what you mean by " attitude angle" ...  Whatever, just observe how the drone is reacting to abrupt throttle stick release, which you've applied. She will try to brake and stop immediately, which will require a rapid change of forward thrust to just the opposite. I'm not sure if that's exactly 45 deg swing, just guessing. Simultaneously the gimbal is trying to maintain stable camera position, but excessive forces involved are making it difficult. That's why you see occasional jump. I believe.
Ya make sense. Some people claim they never see it though. Just makes it suspicious that it is defect. BTW attitude angle is very important in aviation...
2019-12-1
InspektorGadjet
Guorium Posted at 11-30 19:52
You are welcome! Glad it helped.
2019-12-1
InspektorGadjet
AntDX316 Posted at 11-30 18:19
Very true!
Would be interesting to see some of this info clarified by DJI themselves...
2019-12-1
AntDX316
InspektorGadjet Posted at 12-1 02:44
Very true!
yeah, but we will never know about it
We won't even know if they do secret revisions.  I've had hard drives w/ the same model number and everything but the PCB layout was completely different, and I mean Completely different.  One of the big chips was in a diamond position and the other in a square.  It ran fine in RAID-0, though.
They've done "secret" revisions with the Spark battery clips.  The unfortunate souls who still have the older clips w/ no idea and no methods to keep the battery on such as a rear battery clip will end up with a "the drone fell out of the sky by itself" in the future.
2019-12-1
InspektorGadjet
AntDX316 Posted at 12-1 02:46
That is not good, if we are all beta testing this product, we should know of any hardware change...
2019-12-1
Gu5s
Czechia
Guorium Posted at 12-1 00:30
After today's 1hr session I sadly (or luckily?) have nothing to report - the behaviour at question did not occur...
Maybe it was just gimbal sitting way at back - you know as it is written in manual, that if needed you should gently pull it out.
2019-12-1
Guorium
Gu5s Posted at 12-1 06:06
which page in the manual? I read the whole thing and I do not recall such statement.
2019-12-1
Gu5s
Czechia
Guorium Posted at 12-1 07:02
huh that seems to be fault on my part - I thought I must have ready it somewhere, but it seems like it was most likely some comment here on forums...
2019-12-1
Matthew Dobrski
Guorium Posted at 12-1 01:54
Oh, you mean "maximum angle at which a given plane is climbing up"? Yes, obviously it's determined by many factors, but that's not the case here. And yes, your gimbal may be simply defective, although I've experienced such glitches with Osmo Pocket gimbal when exposed to hard shakes and strong wind gusts.
2019-12-1
Guorium
Matthew Dobrski Posted at 12-1 13:22
How about when you tilt the osmo pocket handle more than the gimbal tilt angle limit.
2019-12-1
Matthew Dobrski
Guorium Posted at 12-1 15:01
I don't know. All I know is that these miniature gimbals don't like shaky situations. Be gentle on them and you should be fine ...
2019-12-1
