Mavic Mini Release Notes (12/31/2019)
1234Next >
39280 127 2019-12-31
DJI Support
Flight distance : 2408 ft
Overview:
  • Date: 2019.12.31
  • Aircraft Firmware: v01.00.0400
  • Remote Controller: v01.00.0400
  • DJI Fly App iOS: V1.0.4
  • DJI Fly App Android: V1.0.4
What’s New?
  • Added feature to unlock GEO zones (requires DJI Fly v1.0.4 or later).
  • Added feature that disables takeoff when the GPS signal is weak (GPS <8) and the environment light is not sufficient. This feature can be disabled manually (requires DJI Fly v1.0.4 or later).
  • Added requirement for compass calibration before takeoff when the environment light is not sufficient and the compass experiences interference.
  • Adjusted flight altitude and distance in payload mode.
  • Added warning prompt for battery cycles.
  • Reduced noise during self-diagnostics after powering on.
  • Fixed issue: linking was abnormal in some regions.
Notes:
  • Note that the update may reset various main controller settings, such as the RTH altitude and the maximum flight distance, to default settings. Before updating, take note of your preferred DJI Fly settings, and readjust them after the update.
  • If the update fails, restart aircraft, remote controller, and DJI Fly or DJI Assistant 2 for Mavic, and retry.
2019-12-31
djiuser_GtxfIsqkfaQ3
FINALLY THX A LOT!!!!!!!!
2019-12-31
savalli1.hotmail
Mi aspettavo + funzione ma nulla d' importante..sono deluso..
2019-12-31
djiuser_yxchdgQMaLYw
Maldives
Made the update (both Go App and Drone), still can’t unlock restricted zone.
2019-12-31
LegendEffects
Flight distance : 1227 ft
Philippines
Op, there we go
2019-12-31
edrumor
Flight distance : 695646 ft
Thanks for the new Update!
2019-12-31
Maldives
why isn't it possible to unlock Restricted Zones (Red Zone)...thought this would be possible with the update?
2019-12-31
Mudassar
Flight distance : 76391 ft
China
great .. now people can have fun ...
2019-12-31
fansd915516c
Malaysia
App atill crashes on a note10+...
2019-12-31
SUNNY 2461
Flight distance : 275197 ft
Bangladesh
Damn!!! thankyou Dji <3
2019-12-31
djiuser_70u9DQze4rHH
Flight distance : 4767 ft
Dji Fly app still dont work on exynos processors in Samsung galaxy s10 series and note 10 after Android 10 update. Thank you Dji you are great...  I cant fly with my mavic mini.
2019-12-31
Cristian M
Flight distance : 2638 ft
Hi everybody, can I have more info about  what as changed in payload mode? What's the meaning of "Adjusted flight altitude and distance in payload mode" in the release note?
2019-12-31
Earth_blazing
Flight distance : 57428 ft
This seriously angers me that I still cannot update my phone because your app is incompatible.
2019-12-31
Droneflier
Flight distance : 1811322 ft
So far I see an improvement nothing related to what the update shows - 1) No problems with drone showing payload error when I have nothing on or around the drone - 2) No more over power warnings - 3) I am now able to take my CE version up to 50 meters and 200 meters away from me with out loosing signal - 4) I am also getting a bit more fly time out of the batteries - 5) The only problem I have is every time I power the drone off and power up again I get asked to calibrate the compass
2019-12-31
tshansen
Flight distance : 569820 ft
Amazing, thank you for this :-)
Took my drone for a small testflight, everything seams to be ok. But now my drone picks 5.8ghz instead of 2.4ghz like before. Will try it for a longer test flight and see how the range will be affected and if the ghz change by itself when in auto. (Norway)
2019-12-31
Elsmeghead
Flight distance : 3421503 ft
Thank you for the update DJI. You delivered on time (at the end of December) as promised.
Maybe all those impatient little babies will stop their crying now.
2019-12-31
Elsmeghead
djiuser_70u9DQze4rHH Posted at 12-31 03:35
2019-12-31
Jim02ss
The android app version 1.0.4 is not available yet in the USA.
I just checked the google play store again now.
2019-12-31
George GR
Flight distance : 2990653 ft
Jim02ss Posted at 12-31 05:39
check here 1.0.4
2019-12-31
djiuser_WLnx9Iu3q5ou
Flight distance : 47920 ft
The New Version for Android from dji didn't work on my S10. The 1.0.3 still works for me
2019-12-31
Elsmeghead
Be cautious when flying in low light on this firmware.
Please read this description of the video first...
"When flying in darkness with the .01.00.0400 firmware, the flight characteristics change without warning.
Launched the mini in Cinesmooth mode then turned out the lights. Yaw speed increased as did the amount of drift.
This was expected due to the lack of GPS and the inability for the downward vision position sensors to work in such low light, but the lack of an audible or visual warning from the FLY app is what may catch a few people out."
Reason for this video, is that many people are going to be out tonight filming fireworks for New Year's Eve. Cinesmooth mode will NOT fly as expected in the dark. It will be more like flying in Atti Mode with the yaw speed of Sport Mode. Please be aware of this before any more Mavic Minis go bye-byes before 2019 is out.
2019-12-31
djiuser_JNwA7VB2JTMY
Flight distance : 240476 ft
djiuser_yxchdgQMaLYw Posted at 12-31 02:39
Where is app V1.0.4? It's not on google play!
The drone firmware seems automatically updated this morning. But I experienced some issues: more than 10min flight telemetry data is shown in the app almost blank (1s); return home cause a near crash....
How do I provide the data for further analysis?
2019-12-31
KlooGee
Flight distance : 16783757 ft
Unlocking of blue authorization zones worked for me after this update. However, to get it to work, I had to use the sticks down-and-in method for it to bring up the unlock prompt.  Pressing the auto takeoff button in the app didn’t do anything.
2019-12-31
RDJCo
Still not working with Pixel 3 XL & Android 10, even with the new v1.0.4
2019-12-31
djiuser_uFVTLhzoGgFQ
Flight distance : 418770 ft
Turkey
George GR Posted at 12-31 06:52
check here 1.0.4
Thank you! I couldn't fly with v1.0.3 indoor after firmware update.
2019-12-31
[ p a k a l ]
Flight distance : 57608 ft
Luxembourg
I could be nice to have RAW photogfraphy on the next update ...
2019-12-31
ulfw
Flight distance : 281381 ft
No Panorama (and wish: RAW) is so disappointing. I regret having swapped my Spark that shot beautiful high res panos with this
2019-12-31
Niknik
Flight distance : 1595640 ft
DJI what are the limits in payload mode?
2019-12-31
djiuser_F3WsiEueC1Kf
Android app v1.0.4 NOT AVAILABLE in google play store!! Only v1.0.3 and doesn't work with the dron latest update!
2019-12-31
George GR
djiuser_uFVTLhzoGgFQ Posted at 12-31 10:02
1) Uninstall dji fly
2) Delete dji folder
3) download the application from here is 1.0.4 (but it says dji 1.0.3 did not change it but in the file you download it will be 1.0.4)
4) Do the installation
and enjoy
2019-12-31
George GR
djiuser_F3WsiEueC1Kf Posted at 12-31 11:48
3) download the application from here is  (but it says dji 1.0.3 did not change it but in the file you download it will be 1.0.4)
and enjoy
2019-12-31
FernandoSedrez
Flight distance : 23993 ft
Working fine on my iPhone iOS 13.3, Now I can unlock the Blue Zone to fly.
I think this update took too much time to only enable unlock GEO zones...
We're expecting more features like Raw, Active Track, Pano, 360, Manual options when recording... Only half of it I would be grateful.
Anyway, thanks for being right in time, the real late december.
2019-12-31
djiuser_KCp7Licss3VC
Boa tarde, estou muito preocupado, adquiri um Mini Mavic e não consigo instalar o app no meu celular, uso hj um Moto Z² play com Android 9. O que fazer alguém pode me ajudar????
2019-12-31
edrumor Posted at 12-31 02:52
You are more than welcome. Thank you for your valued support and happy flying.
2019-12-31
djiuser_3j8HVbhGlxSZ
Waiting for FPV goggles support.
2019-12-31
MatthewW28
Flight distance : 11460925 ft
Kind of sad because all the Christmas celebrations and other events have already passed and I would have loved to fly as they were in authorization zones and I also missed my opportunity to go to NYC.  At least I could try again next time.
2019-12-31
KlooGee
djiuser_yxchdgQMaLYw Posted at 12-31 02:54
Red restricted zones need to be unlocked via a custom unlock on their website.  This has been the requirement for all DJI drones for as long as I've known their system.
https://www.dji.com/flysafe/custom-unlock
2019-12-31
KlooGee
MatthewW28 Posted at 12-31 16:37
Between federal and local regulations, there pretty much isn't anywhere in NYC where it is legal to fly except for a handful of local parks.
2019-12-31
KlooGee
djiuser_3j8HVbhGlxSZ Posted at 12-31 16:08
Unfortunately, I'm guessing you may have quite a long wait for that one.  Not sure that will ever come.
2019-12-31
KlooGee
Elsmeghead Posted at 12-31 07:28
Just to be clear, the behavior described is specific to low light AND no GPS signal.
It will work just fine in low light assuming it has a robust GPS signal.  It only defaults back to visual sensing system when it is at low altitude and there isn't a lock on the position via GPS.
Also, this is not specific to the Mini or this particular firmware update.  This is the same behavior for every one of DJI's drones for as long as I've been involved with them.
Cheers!
2019-12-31
1234Next >
