JJB*
Flight distance : 12566335 ft
InspektorGadjet Posted at 1-4 10:04
Ok @JJB so I have performed some tests and I can confirm, full throttle going forward right stick up, press quick RTH while maintaining right stick full throttle up, mavic mini pauses and it hoovers, I repeat with right stick engaged full up. So not only works in quick shots and RTH, also flying manually.
I can post logs if needed but all I wanted to say with this is that some users reported commanding RTH and mini didnt came, but drifted in the wind or flew away, but the thing is you must press and hold, and listen to the screen indications/beeping that indeed is trying to RTH, only quick press makes mini pause and hoover, and in a windy scenario the drone will drift, loose signal, loose power, land or crash.
thanks for the tests, and ofcourse after press RTH you will see in the app that the mode is changed.
check, check anddouble-check ;-) |
