Mavic Mini - Max Range 100m !!
6533 19 2019-12-2
djiuser_8swv5HtRyJ8h
Philippines
I am a previous owner of a Mavic Pro with lots of flying experience, so was excited to get my hands on a Mavic Mini
On my first flight over the weekend, I flew in a relatively open space but couldn't fly beyond 100m.......twice I tried and got to 100m and 50m, before i lost connection and the phone screen went blank and the RTH (and a bit of panic) kicked in.
Everything else seemed to be fine, video was good and clear, the Mini was stable in moderate winds and the controls seemed to be responsive.
I will try to get out again in the next couple of days to see if the problem persists, but my intial thoughts of the Mavic Mini are not good at all
2019-12-2
Cap0ne
Flight distance : 217077 ft
Romania
Same for me in the city, +/-25m depending on the obstacles or interferences...
Try to mentain a clear line, without any obstacles between the remote and the drone. Also try to move the antenas so you have them as much as "perpendicular" to the drone as you can.
2019-12-2
Philippines
Cap0ne Posted at 12-2 01:30
Yeah, I wasn't in the city......I was actually in the middle of a lake when it lost connection and RTH'd.
It was a wide open area, but there was a mall about 750m away on one side, so maybe that added to the interference,.....I also had the antenna correct.
I will try again in a different area later this week.
2019-12-2
__Raven__
Flight distance : 135052 ft
Which model of the remote do you have? One of the models only allowed a maximum range of 500m due to legislations.
2019-12-2
Did you have prop guard cage on, this has flight limit when it is on the drone ?
2019-12-2
Philippines
hallmark007 Posted at 12-2 05:08
No.....no prop guard
2019-12-2
Philippines
__Raven__ Posted at 12-2 04:22
I am in a country (Philippines) with no restrictions.....so was expecting the unrestricted model......but i will check
2019-12-2
JodyB
Flight distance : 302536 ft
Interesting, even for the CE version I would think would have better range, except if there was some kind of RF interference, or other kind for that matter.
2019-12-2
Philippines
JodyB Posted at 12-2 06:02
Yeah I just read even on the CE version......there is a range of 2km at 5.8 GHz and 500m at 2.4 GHz
2019-12-2
Minnesota
Shut off the Payload button in settings.
2019-12-2
JodyB
Minnesota Posted at 12-2 06:07
Would having payload turned on limit your range like that? I haven't turned that on to see what it does on mine yet but I would think it should give you a warning and not just loose connection like that.
2019-12-2
Philippines
I believe it was set to off......but will check when I am out flying next
2019-12-2
djiuser_zAEWGVrRCQoT
Same here, I owned a Mavic mini.
I can only fly like 100meter and sometimes not even 100meter and the drone keep RTH. Any solution that can improve the range, DJI shown Mavic Mini can fly 500meter....
2020-1-27
German DroneTV
Flight distance : 741864 ft
djiuser_8swv5HtRyJ8h Posted at 2019-12-2 06:07
So much disinformation here...
2000m 2,4GHz
500m 5,8GHz
I can reach in a CE country 4000m+ with my Mini.
I think your remote or Mini is defective
2020-1-27
German DroneTV
2000m 2,4GHz
500m 5,8GHz
2020-1-27
fanse342676c
Flight distance : 263225 ft
Portugal
djiuser_8swv5HtRyJ8h Posted at 2019-12-2 03:17
Maybe the Mall was interfering with your signal due to multiple wifi hotspots that are inside malls creating a large interference with the controller signal. Also, the lake may help the inteference from the mall.
I have seen a Youtuber that was flying his Mini for the first time during vacations and he tried to fly the Mini over a lake in the hotel he was staying. He couldn't get more than 20 to 30 meters before losing signal. He wanted to return the Mini when he got back from vacation but decided to try to fly the Mini on an open area. He got more than a 1 Km range and realized that when he was at the hotel over the lake the interference from the hotel guests wifi hot spots were the culprit for the low range of the Mini.
2020-1-27
ninjate
Flight distance : 84232 ft
Austria
Are you forcing / manually setting to 2,4GHz?
I have the CE version and the interference in my neighborhood is so bad that at 2,4GHz I can do max 150meters.
If I leave it at auto or manually set to 5,8GHz then I can do 600meters.
With a 3rd party antenna (like 4Hawks Raptor SR) I can hit 1km in same neighborhood at 5,8GHz (but 2,8GHz still can only do 200meters lol).
2020-1-27
Ingo Sundowner
Flight distance : 914012 ft
I flew mine to 1.2 km and then back. No probs. Sure I could have easily made 1.5-2km
2020-1-27
cellork
Flight distance : 29386 ft
Romania
I don't know what are you talking about, my mini just went yesterday 1.4km (0.87miles) , wich is impressive with no accessories whatsoever. And with a yagi 2.4Ghz range extender it got farther than 2km (1.24 miles). I was skeptical at the beginning but it went no problem near a small airport and a medium sized city. Note that i was flying it to the airport, not from. The problem was in height, it didn't want to go higher than 100m (328 ft), it was losing signal above that. I didn't limit anything. Anyways, i don't know why you want to go higher than 100m.
2020-8-21
hEx_PL
Flight distance : 50187 ft
Unfortunately, the Mini doesn't do very well in the city. It's not easy to find a good place to fly in the city, but it's not impossible.
2020-8-21
