Flight distance : 11959747 ft
Reedham Posted at 2-6 01:42
I did take off before it had a GPS lock however as slup spotted I then hovered at a low level until I got a white GPS indicator before heading up. I think compass errors would fit with the behavior however I’m not sure what would cause that. The compass was calibrated on the flight before and it’s the first time anything like this has happened. Take off was from ground level on wood decking next to the house so not near any significant metal. I’m just glad I got control back before it headed off and over the river, I’ve got DJI refresh however obviously I need to be able to recover the drone for that to help!
I’ve uploaded the dat file to my Google drive https://drive.google.com/file/d/1s-tjtF8EgmbrY_MeJyNtGUJFMUYGA6yD/view?usp=sharing
It doesn’t take significant amounts of metal to interfere, calibration the night before won’t help with new interference.
Some rules for checking your clear of magnetic interference. They are a guide.
Compass distances.
Natural and Artificial Magnetic Anomalies Warning
Note
The following information has not been objectively tested to determine it’s impact on a Drones compass accuracy in flight.
1 Many things can distort the earth’s magnetic field in the area you are flying:
• Steel framed or reinforced concrete buildings, bridges and roadways, iron pipes and culverts, high power electric lines, heavy equipment, trucks and automobiles, steel tanks, electric motors and even computers.
• Flying between steel framed or reinforced high rise buildings will distort the magnetic field in addition to causing GPS multi-pathing.
2 Safe distances for compass calibration
• 6” (15 cm) minimum: Metal rim glasses, pen/pencil, metal watch band, pocket knife, metal zipper/buttons, belt buckle, batteries, binoculars, cell phone, keys, camera, camcorder, survey nails, metal tape measure.
• 18” (50 cm) minimum: Clipboard, data collector, computer, GPS antenna, 2-way radio, hand gun, hatchet, cell phone case with magnetic closure.
• 6 ft (2 m) minimum: Bicycle, fire hydrant, road signs, sewer cap or drain, steel pole, ATV, guy wire, magnets, chain-link fence, bar-wire fence, data collectors
that use a magnet to hold the stylus.
• 15 ft (5 m) minimum: Electrical box, small car/truck, powerline, building with concrete & steel.
• 30 ft (10 m) minimum: Large truck, metal building, heavy machinery.
How magnetic interference happens on the ground and the results.
The best way I can explain this is. If you put your Aircraft on the ground in normal circumstances, start it up, then lift it up and turn it 90 degrees to the right both your compass heading and IMU will both move together 90 degrees and no problems.
If you put your Aircraft on the ground and there is magnetic interference only the heading of your compass will change, your aircraft will still take off. But when it clears magnetic interference compass will then move to correct heading which you would think was great. But No, what happens is IMU is then conflicted and confused because of this sudden movement by compass, so you receive IMU exceptional heading warning, your aircraft cannot deal with data conflict so decides to switch to Atti mode dropping gps in favour of compass simply because aircraft can fly without gps but not compass.
While I can’t be certain you picked up interference from the ground or surrounding area it is the most common cause.
