Strange colour shift
5575 23 2020-2-3
mockingbird_71
Flight distance : 45459 ft
media removed
2020-2-3
Hi. Thank you for reaching out to DJI Forum. Upon checking the video this is normal since the drone's camera is facing the sun and you will notice that once the camera tilted down the effect of the light was reduced which caused the color to change. Just a friendly reminder, you may need to use an ND filter whenever you are taking or shooting video footage that is facing the sun to reduce the effect on your videos. Thank you.
2020-2-3
Two things combining here to cause the problem. You are shooting towards the sun, and there is lens flare in the top of frame that is shining on the sensor, even though it does not necessarily show in the video. And the mini has auto-colour temperature setting, that has been triggered by the flare to produce an erroneous setting.
2020-2-3
42Neil
Another good example of why we ideally need manual white balance control or at least an Auto WB lock function.
2020-2-3
mockingbird_71
Thanks for the feedback geebax  ! I will pass on your thoughts to the friends who are having the same issue ! And will have a look again next time we are out flying ?
2020-2-3
m80116
Flight distance : 3264131 ft
Not only you can expect lens flare but also photosites filter reflection inside a sensor module... they usually appear as confused circles of colors in the picture.
For my experience MM has a moderately good resistance to flare and the effect is quite pleasant but quite present since the lens is rather flush, thus getting light rays even at steeper angles. The best solution that I can think of is getting add-on ND and PL filters which I have and I feel they help quite a bit with that.
Sometimes flare is just natural and I feel it doesn't get in the way, thus giving a scale of how hard the light really is.
2020-2-3
deathsquad
Flight distance : 6763835 ft
You can thank automatic white balance for that.
2020-2-3
Jim_H
Flight distance : 787152 ft
Malaysia
yup, experienced the same thing, was shooting an aerial view of the stadium, the track colour changed plenty when i move away from it...
Sad thing is cant do anything about it until DJI decided to update and add features in their FW...
We will need to live with this...
2020-2-3
Jim_H Posted at 2-3 21:32
"We will need to live with this..."
Not if you are using a half-decent editor to post produce your footage. The better editors allow you to change the colour temperature.
2020-2-3
Dmitry Vishnevskiy
Flight distance : 588635 ft
It is "normal" for Mini with current firmware/app and auto WB...
2020-2-3
Jim_H
Malaysia
Geebax Posted at 2-3 21:36
that's true.. but too much of a hassle..
should make more noise for DJI to listen i guess?
2020-2-4
mockingbird_71
From my experience dji don’t listen ! Especially to customer feedback ! I’ve been waiting months for feedback on my iPad issue ! An iPad that’s on their own approved list fails to run the go 3 software , disconnecting the live view and all the other ! Settings ! Sending them videos and lusts of app versions and all other kinds of files ! No response what so ever !
2020-2-4
mockingbird_71
Duplicate post
2020-2-4
Flight distance : 10186312 ft
Jim_H Posted at 2-4 00:22
You say to much hassle, but surely it would be the same hassle filiming into the sun if suddenly the sun was covered by the cloud, filming with drones is never simple and nearly always requires post work, unless your happy with what you get out of the camera, which is fine, white balance lock won’t take care of all the woes people think it will .
2020-2-4
mockingbird_71 Posted at 2-4 07:32
What’s go3 ?
2020-2-4
mockingbird_71
hallmark007 Posted at 2-4 08:26
What’s go3 ?
Dji go app version 3 used on the phantom 3 pro!
2020-2-4
mockingbird_71 Posted at 2-4 09:15
Ok got ya .
2020-2-4
Jim_H
Malaysia
hallmark007 Posted at 2-4 08:24
well.. just need to figure out a way to work around it i guess, ie not shooting directly to sun, change composition etc..
all tools have it's pro and cons..
2020-2-4
42Neil Posted at 2-3 13:57
This would not (completely) solve the issues.
The internal lens flare would still make a greenish overcast on parts of the frame (depending on the angle the light hits the lens)
But I agree I would most certainly want a drone that has manual mode in video.
(and AEB)
2020-2-5
Ice_2k
Flight distance : 1132575 ft
Romania
i actually like the effect of passing through a lens flare from the sun, I use it quite often in my films. The WB changing because of that flare would indeed totally ruin the shot.
2020-2-5
KlooGee
Flight distance : 16783757 ft
I agree with many of the comments about the changing white balance here.  DJI really needs to give us back manual control in video like they do in photo mode.  As some have mentioned here, it doesn't fix the problem for all scenes, but being able to lock the white balance would make it easier to control many scenes and give a bit more predictability in other scenes.
2020-2-5
mockingbird_71
KlooGee Posted at 2-5 07:04
They need to sort out the issues with distance first im getting weak signal warnings at less tan 100 metres which says to me the firmware needs tweeking, I dont use dji support anymore as the tech dept dont respond to your issues anyway. sending videos and logs and never get back to you!
yes the picture adnd white balance would be a great addition. there are lots of things that could be done if DJI listen to the feedback.
2020-2-6
mockingbird_71
Ice_2k Posted at 2-5 06:47
I was trying to capture the shadows from the arches more than anything ! it was a great video in my opinion. like has been said maybe dji need to listen to feedback from its customers, and give a level of control to the end user .
2020-2-6
mockingbird_71
So does anyone on the forum know if dji are working on re introducing manual white balance to the fly app whilst using the mavic mini?
2020-2-25
