DJI RTK SDK Controller Apps
4868 9 2020-3-2
sputnik7
Hi all!
Does anyone know if there are any known apps that run on the RTK SDK controler ?
It has been over six months since i purchased my RTK SDK controller and its still in the box!
Are there any known apps out there or any in development ?
Would just like to knoww what to do with it really cost me $750 euros... if it has no known use or purpose then is there any way to get my cash back as I bought it form a DJI certified dealer... and really need another Mavic 2 Pro
Thanks!
2020-3-2
guillermomeiner
Argentina
GS Pro is the app for that controller. A special version for mission planing. It had an update in december with several changes
2020-3-2
guillermomeiner
Argentina
https://terra-1-g.djicdn.com/851d20f7b9f64838a34cd02351370894/Firmware/ag410_v02.02.0307.bin
2020-3-2
sputnik7
i really mean third party apps - the device was sold as a SDK controller to run third party applications on since the RTK already ships with a version of GS
but at least thats a start as i have been trying to get  GS PRO to work as well and was unable to
how do i link my DJI RTK drone to the DJI RTK SDK Controller in order to run GS PRO ?
I am unable to link it to the controller as the DJI GO 4 doesnt support the RTK drone
2020-3-2
guillermomeiner
Argentina
sputnik7 Posted at 3-2 12:46
Haven't heard about other apps for using the controller.
The link its easy
page 40
http://dl.djicdn.com/downloads/p ... nual_v1.4_EN_en.pdf
2020-3-2
sputnik7
Thanks for the help!
i have been there that is to link it to the controller that ships with the RTK
how do you link it to the RTK SDK controller ? to link it you need to run a app on the tablet... like DJI GO 4
is there a way to link it using the GS PRO app ?
other than that basically am i right that  there are no developers supporting the RTK SDK controller basically is that what you are saying ? and the only use for it is with the GS PRO app ?
the regular phantom 4 controller is supported by MANY third party applications...  like Pix4D and drone deploy etc.
i am trying to find out if any of these applications are coming to the RTK as that is what the RTK SDK controller is for correct ? SDK (Software Development Kit for 3rd parties)
thanks again !
2020-3-2
guillermomeiner
Argentina
sputnik7 Posted at 3-2 15:43
1) To link the controller with the drone you need to link just the way it says in the manual. If i am not wrong you don't have to open gs pro app (its a one time process), you go to the upper left corner, tap on device management (like a drone icon) and then you just follow the described on the manual. Its reaaaally easy, and again, it is done just for the first time, then it's just a "turn on and paired" method.
Paired or not you can work with planification process in Gs Pro, but not with the execution process. For that last part, obviously you need a linked aircraft.
2) Correct, a i dont know about any other apps which can run on the P4RTK controller (like dronedeploy for example). But, i have to say it, GS PRO is in VERY good level. Maybe some tools needed, or better maps (like google services)
3) Yes, regular phantom 4 is supported by many other app, like pix4d or dronedeploy. Not P4RTK case.
4) Yes my friend , an SDK controller should have a lot of apps working on it. Not P4RTK case.
2020-3-3
fans31104d30
Flight distance : 1014872 ft
Portugal
I'm using the P4RTK with and SDK controller and iPad. The problem is that, for some strange reason, the P4RTK does not produce a Survey folder with the necessary files for PPK. I had to buy an Android tablet and use DJi Pilot to be able to get the "Survey" folder. It would be so great if DJi could produce a unified app to use with a premium priced drone....
2020-9-7
jivago
Flight distance : 23671 ft
Check Map Pilot app on iPhone.
2020-9-8
fans31104d30
Portugal
Map Pilot cannot produce a Survey folder also. As in GS Pro, the photos get the RTK updated info. However we cannot do PPK in either option.
I don't know what is the reason for being able to produce a survey folder in android and not in iOS. DJi's typical idiosyncrasy.
2020-9-9
