Mavic Mini Prop Strike possible FIX/SOLUTION?
2872 21 2020-4-1
sergeant
Many are talking about the issue of the DJI Mavic Mini props hitting the body of the drone during flight although this only really affects operators that fly their drone in a certain 'volatile' way. It's not a problem for all users, but this video has a fix and solution which costs nothing and should stop it happening again.
It's worth noting however that this third-party suggestion may invalidate the waranty, it might also cause overheating of the motors - but for users that fly in a volatile way, this might be their only option to stop prop strikes on the drone body.
2020-4-1
Renato61
Flight distance : 168163 ft
Risk of engine overheating?
2020-4-1
Probably void the warranty though.
2020-4-2
StubbornSwiss
Flight distance : 480771 ft
Interesting to see that the video, with its in depth analysis followed by product advertising, is done by someone who does not even own the Mavic Mini.
This is nothing more than an advertisement!
2020-4-2
sergeant
StubbornSwiss Posted at 4-2 03:01
Why would you need to own a Mavic Mini to report on an issue which is affecting lots of Mavic Mini owners? And the piece at the end of the video is merely to say that this issue shouldn't put people off buying it because it only affects a certain style of flying.
2020-4-2
Cal Evans
Flight distance : 85673 ft
GREAT video!
Thanks.
I love the dust caps.
Cheers!
=C=
2020-4-2
captqbec
Flight distance : 230 ft
How much weight do they add?
2020-4-2
sergeant
captqbec Posted at 4-2 03:45
Not sure of the weight, but they look incredibly light, a few more grams won't affect flying performance, however they may take the drone over the 250g weight limit.
2020-4-2
That would be too bad (if it would get over 250gr)
2020-4-2
captqbec
Montfrooij Posted at 4-2 04:56
...just for the front arms maybe?
2020-4-2
captqbec Posted at 4-2 04:57
Might be enough, but still it needs to be <250 to be interesting in the EU.
2020-4-2
StubbornSwiss
sergeant Posted at 4-2 03:15
I thought from the video title that it was about a "Simple Fix/Solution", as opposed to just reporting on an issue that has been reported on numerous times.
Personally I prefer to get fixes/solutions from someone who has actually experienced the problem and can confirm the fix/solution.
Nonetheless....... each to his own.
Stay safe!
2020-4-2
sergeant
StubbornSwiss Posted at 4-2 05:31
It's pretty obvious that the prop strikes occur before of clearance between body and aircraft, therefore raising the height of the props will clearly solve this. You don't need to have had a car crash to know how to avoid having one...
2020-4-2
Renato61
The proposed solution may be interesting, but do partially deformed propellers have the same performance?
2020-4-2
StubbornSwiss
sergeant Posted at 4-2 05:39
Lol........ you're a funny man.
You sound like your typical back seat driver.
2020-4-2
sergeant
StubbornSwiss Posted at 4-2 05:48
And your username absolutely suits your trolling.
2020-4-2
TDZHDTV
Flight distance : 2068550 ft
The caps add 4g which isn’t going to be an issue in Europe come July 2020 when we all will be required to register our Mini’s due to inclusion of a camera.  Don’t buy the Sunnylife covers they are garbage, there is a link in the video of alternative manufacturer.
2020-4-2
fans23214ef8
TDZHDTV Posted at 4-2 06:24
Any motor overheating heard of?
2020-4-2
TDZHDTV
fans23214ef8 Posted at 4-2 06:50
Not that I’m aware of, but it’s still cold here in the UK.  Motors didn’t seem to run hot when I hovered indoors for 25 min.  I don’t have mine fitted at the moment as I’ve been experimenting with tape to stiffen arms... no joy yet.  I think I’ll ultimately make a warranty claim with DJI once they acknowledge the issue
2020-4-2
m80116
Flight distance : 3264131 ft
There was a test w/ motors caps and IR thermometer pistol on YT and the motors temperature wasn't affected, perhaps if there was a delta deviation was negligible. The covers help the motors stay clean which I think is a big bonus.
My caps are SunnyLife, not the same ones of the video but I think they're still providing some additional spacing.
m80's MM back 3/4 L
m80's MM back 3/4 L
2020-4-2
sergeant
m80116 Posted at 4-2 08:31
There was a test w/ motors cap and IR thermometer pistol and the motors temperature wasn't affected, perhaps if there was a delta deviation was negligible. The covers help the motors stay clean which I think is a big bonus.
Precisely and good point - this video did a good test and showed no change in temperature:
2020-4-2
djiuser_QuBvt5rL05Yz
Flight distance : 961 ft
I know this is an old thread but did you find a solution? Im having the same issue. Its not constant but i hear it maybe 1 to 3 times per flight when the drones close. Its only the front right
2020-12-28
