The height of dji spark was not detected correctly while flying
3298 22 2020-4-9
TechCreator
Flight distance : 187274 ft
Malaysia
Dear All,
I had an issue recently as per attached picture. Did anyone can help me to address the issue. I did what was being told by dji support.
1) update latest firmware
2) re-install go 4 app
3) calibrate IMU
Am i having issue with hardware?
2020-4-9
TechCreator
Malaysia
11. 2 feet was stagnant and always around that figure as per my observation, in the past the height will tally with the actual elevation. I never have crash on my dji spark so far.
2020-4-9
TechCreator
Malaysia
The next step i did  change to another android phone but the same issue i face.
2020-4-9
Wolferl
Flight distance : 23793 ft
Austria
Are you using an OTG cable to connect your phone to the remote?
Cheers,
Wolferl
2020-4-10
DJI Natalia
Hi TechCreator, if the issue still persists after all the troubleshooting, you are recommended to send the drone in for a diagnosis.
You may start an online repair request on our official web and then send it back. Here is the link: https://repair.dji.com/repair/index?site=brandsite&from=nav or contact our support team at this link: http://www.dji.com/support to open a case and then send it in.
Please be advised that due to COVID-19 prevention and traffic controls, product repairs and shipment times are expected to be delayed.
2020-4-10
LouisP
Flight distance : 41952 ft
Try cleaning the downward looking sensors.
2020-4-10
TechCreator
Malaysia
DJI Natalia Posted at 4-10 01:52
Thanks Natalia..appreciate your respond
2020-4-13
DJI Natalia
TechCreator Posted at 4-13 19:41
You're welcome. Hope everything goes smoothly, best regards!
2020-4-14
S-e-ven
Flight distance : 5922034 ft
Have you been flying, by any chance, about 4m over a roof?
Upload your flight record to
https://www.phantomhelp.com/logviewer/upload/
And check it out or link the uploaded record to this topic.
2020-4-16
Jakab Gipsz
Hungary
LouisP Posted at 4-10 11:17
The downward-facing sensors are already switched off at this height! In this case, the barometer takes over the altitude measurement.
Try resetting the drone (by pressing and holding the power button) and then calibrating everything.
2020-4-19
Anuvis
Flight distance : 1976736 ft
You have a faulty barometer old story.....I have the same problem ......They will tell you to sent it back etc the known bul...s....
2020-4-19
NRRTRAINS 85
when you first take off and you are hovering what does it read and when you are about to land what is it  . if you can land and take off  i would not worry . fly by line of  sight . i have seen this happen and even in the flight logs .
2020-4-19
TechCreator
Malaysia
Wolferl Posted at 4-10 00:05
Cheers,
i used wifi, when i used otg cable, it is alwalys disconnect in the middle of flying.
2020-6-4
TechCreator
Malaysia
Noted with thanks. I was thinking to sent but due to Covid 19 movement control. I forsee that the respond/diagnose duration will be longer. BTW do i need to send to China or i can sent within my country?
2020-6-4
TechCreator
Malaysia
NRRTRAINS 85 Posted at 4-19 15:11
the height reading while hovering and landing is not tally with actual elevation. The distance have no issue, the reading is accurate. Overall take off and landing , the aircraft have no issue. All was functioning well.
2020-6-4
TechCreator
Malaysia
Anuvis Posted at 4-19 13:34
Really ? yes your are right they ask me to sent to them, but due to covid 19 movement control, i foresee it will take longer time.BTW did u sent to them for diagnose? Finally your problem solved?
2020-6-4
TechCreator
Malaysia
Jakab Gipsz Posted at 4-19 11:42
Thank LouisP, i done what have been recommended , but the height still not improved. I just used my own eyes to anticipate my aircraft height. When i cannot see it, i just press return to home button.
2020-6-4
Anuvis
TechCreator Posted at 6-4 06:02
No i did not sent it problem is not solved
2020-6-15
TechCreator
Malaysia
Cheers,
using wifi and also OTG but same result
2020-8-4
TechCreator
Malaysia
clean up but it is still the same
2020-8-4
TechCreator
Malaysia
Guys..I finally send the drone to remote control shop...the technician just calibrate my IMU and the problem solved. I tried do it my self but it is error. Thanks for responding to my post
2020-11-25
Jakab Gipsz
Hungary
TechCreator Posted at 11-25 05:44
That’s exactly what I said in post # 10, back in April. Why didn't you do that?
2020-11-26
TechCreator
Jakab Gipsz Posted at 11-26 13:48
I did but each time did..appear error....
Get help from.the technician...he did it easily....anyway thanks for the info...
2020-11-26
